11-14-2013, 15:34 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Classified
Member: 1280253 Status: Offline Thanks Meter: 142 | Iphone 5 asking for activation with R-SIM 9 PRO I am using R-SIM 9Pro to use a different sim card as i have a locked iphone 5 , however as soon as i put the R-SIM with a non suppored card in the iphone 5 it asks for ACTIVATION ...... is that normal with R-SIM ???? i think after properly following the instructions there should be no problem with the activation right ???? Can anybody here explain the complete procedure ??????? Pls help/advice br/manbir |
11-14-2013, 16:16 | #2 (permalink) |
Major Poster Join Date: Nov 2013
Member: 2060493 Status: Offline Thanks Meter: 0 | It is normal. My WIND (Italian) sim was not supported on my american iphone 5C locked to AT&T. It didn't even allow me to open itunes. But inserting the r-sim pro and my WIND sim, a pop up window appears, you choose the model of the iphone and then the carrier to unlock. Then click on accept and restart the phone. No need to insert any code. It worked for me. |
11-14-2013, 16:28 | #4 (permalink) | ||
Member: 1280253 Status: Offline Thanks Meter: 142 | Quote:
any idea what the problem might be here ???? br/manbir | ||
11-14-2013, 17:27 | #5 (permalink) |
Member: 2060493 Status: Offline Thanks Meter: 0 | if you get the message invalid sim with the r-sim inserted, ( and I did too ) probably the r-sim9 has to be changed. I actually purchased a second one to unlock my iphone, because the first time I messed things up. This usually happens when you have previously activated the carrier sim on your iphone , using the same r-sim9. Or at least that's what the guy who sold it to me said. So you would have to try the r-sim9 in another iphone with a different sim for activation and done that, re-insert it into your iphone with your sim. This way it won't recognise your sim as before. It's worth a try. |
11-15-2013, 13:45 | #6 (permalink) | |
tried a new one and the same problem ....... R-SIM ??????? modretors ??????? anyone ????????? | |
11-15-2013, 22:16 | #7 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2066212 Status: Offline Thanks Meter: 0 | i have similar problem during activation with RSIM9Pro (iphone5, iOS 7.0.3, JP AU). first i made a clean format with the AU simcard alone and after that reboot with RSIM9PRO & current sim-card. During the activation screen i can get the pop-up menu working and able to choose JP AU from the list. However, after rebooting the phone i cannot finish the activation process, no matter am i using WLAN or itunes. It tries to activate the phone though but after several minutes i will get an error message "could not connect to the itunes server... pls, try again later) There's no problem in the activation with the au simcard alone but nothing happens when RSIM9Pro is used together with any sim-card. I have also used RSIM8 + 3G patch with the same phone but i couldn't get it working at all. Is it possible that RSIM8 is the reason for this behavior even with clean install? |
11-16-2013, 18:45 | #8 (permalink) |
Member: 1280253 Status: Offline Thanks Meter: 142 | R-SIM 9 Pro team ????????? where is the solution to this problem ???? to add i have now tried with 4 new R-SIM 9 pro cards and all of them have the same problem ........ 4s also does not accept this ......... waiting for a responce ........... |
11-22-2013, 06:28 | #10 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 379713 Status: Offline Thanks Meter: 55 | RSIM product known issue is USIM compatibility...maybe thats what happened to you. Different USIM, different country, different result. But i'm pretty sure they wont mention that in their ads... |
11-22-2013, 20:38 | #11 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1414809 Status: Offline Thanks Meter: 155 | I'm having a similar issue. Tried 2 different rsim9 pro on two different att iphone 5 and they both ask for activation but fail to do so. Waste of money on this useless trash. |
12-27-2013, 14:11 | #12 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2093265 Status: Offline Thanks Meter: 0 | Hi guys, same issue with my Iphone 5S, 16gb, iOS 7.0.4. Currently locked to US Sprint. I have used RSIM 9S, I was able to activate the phone (from fresh restore) but after activation I got the same message as guys above "Activation required". I've tried many times, even using different MSI codes and SIM cards, but always got same result – activation required and if I do activation it say’s “server busy” etc. Could you please help? I’m even happy to do jailbreak on the phone, as long as it helps me from using the phone as very expensive iPod Thank you! |
12-28-2013, 08:53 | #13 (permalink) |
Product Manager Join Date: Mar 2013 Location: CH
Member: 1907775 Status: Offline Sonork: 1653265:unlocker Thanks Meter: 2,693 | can not use in sprint iphone5s ,we are currently working hard on sloving this |
The Following User Says Thank You to kinglock For This Useful Post: |
