10-11-2013, 07:43 | #17 (permalink) | |
Freak Poster Join Date: Feb 2013
Member: 1889273 Status: Offline Thanks Meter: 12 | Quote:
in iphone 5 japan auu who u can get 3g work? what you install? | |
10-11-2013, 22:18 | #19 (permalink) | |
Freak Poster Join Date: Sep 2013 Location: United States
Member: 2033138 Status: Offline Thanks Meter: 17 | Quote:
try sending msg without prefixing your country code showing roaming means the line is still active on your phone means you can still make or receive a call on that original no. | |
The Following User Says Thank You to hemank5 For This Useful Post: |
10-12-2013, 04:57 | #21 (permalink) |
Member: 2033138 Status: Offline Thanks Meter: 17 | I didn't install anything special when I was on 6.1.4 only at that time patch was installed and updated the phone using the inbuilt updater . Since my operator apn is I think resides inside by default from apple that's y I didn't need to install apn manually I prefer you try installing the carrier apn of yours from unlockit Actually I am little bit confused about japan au carrier that how my phone is able to connect to internet and send message as when I try to open personal hotspot it says contact kddi which I think means line not active . I have tested much only on sprint phones only I can guide you all about sprint only ... For Japan au kddi I am also little bit unsure how it worked out if you are facing problem |
10-12-2013, 09:07 | #22 (permalink) | |
but idk why ur msg is not working!!!! btw ussd codes are not working in any of the phones unlocked on ios 7 with rsim | |
