12-16-2014, 18:14 | #1 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2303032 Status: Offline Thanks Meter: 2 | iPhone 5 ios 8.1.2 jailbroken can't activate R-SIM 9PRO Can't activate... Any packeges I should install etc.? |
The Following User Says Thank You to Croatian For This Useful Post: |
12-17-2014, 22:10 | #5 (permalink) | |
Freak Poster Join Date: Oct 2014
Member: 2274130 Status: Offline Thanks Meter: 16 | Quote:
You must define what carrier it is locked. Verizon cost 40$ At&T 40$ Uk Vodafone, Orage cost 55$ Sprint cost 120$( but you can't reset, because iphone will be relocked again). | |
12-18-2014, 07:13 | #7 (permalink) |
Freak Poster Join Date: Feb 2010 Location: ┌(◣◢)┐
Member: 1239963 Status: Offline Sonork: Coming Soon Thanks Meter: 42 | uk orange i5 support by server please sorry my friend but uk orange by server average is up to i5 clean devices, usd 55.00 processed in 5 working days. not available for i5c / i5s... yet, but if someone else have this service till i6/ i6+ kindly let me know by pm urgently for the same uk orange. Br |
12-22-2014, 12:33 | #10 (permalink) |
Member: 2315191 Status: Offline Thanks Meter: 0 | Got it working I installed patch A from the repo isamteam .com (the one that says ios 8.x), then after respring, opened the the newly created app "r-sim" tapped on the first blue button, installed the apn. re insert the sim, use at t, i5 then I used ios 7.0 - 7.06 instead of 7.1.x. And that's it, i still have to check if i can receive calls, apparently i can make calls. also i have to check data and sms |
12-25-2014, 17:18 | #12 (permalink) | |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | Quote:
12-25-2014, 17:23 | #13 (permalink) | |
You need USSD: Open Cydia, make sure commcenter patch is installed, if not add source repo apt.chinasnow and then install it, install iFile, go into iFile, go to /var/mobile/Library/Carrier Default.Bundle, click on carrier.plist, Property List Viewer, turn on SupportsSupplementaryServicesOver3GPP, and restart. Sometimes, you need to add that boolean string to the bundle that you're using(Carrier Bundle.bundle instead). | |
12-25-2014, 17:24 | #14 (permalink) | |
