09-27-2013, 10:00 | #1 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2034932 Status: Offline Thanks Meter: 0 | iPhone 5 Japan AU -- RSim 8+ and RPatch not function-- Italian operator I have iPhone 5 from Japan AU with iOS 7.02. I bought RSim 8+ and installed it, the voice and sim switching is quite fine with italian Vodafone but not with italian H3G. SMS and internet navigation is BAD. I bought the RPatch code (I received the code today) but when I load the program it does not ask me the activation code in no way...it shows the device info and write device found but not asking the activation code, so I can't patch and I don't know how to do. Please help |
09-27-2013, 10:07 | #2 (permalink) |
Insane Poster Join Date: Sep 2013 Location: iPhone Land
Member: 2031214 Status: Offline Thanks Meter: 8 | Have you clicked the install button? If not then click it, after you click it, then select unicom, then the patch will ask you to insert the activation code. |
09-27-2013, 10:14 | #4 (permalink) |
Member: 2031214 Status: Offline Thanks Meter: 8 | What version of the patch do you using? Make sure you downloaded the patch from R-SIM PATCH | iPhone 5/4S 3G & SMS bug fixer |
09-27-2013, 11:41 | #6 (permalink) | |
Freak Poster Join Date: May 2006 Location: Malaysia Kuala Lumpur
Member: 276082 Status: Offline Thanks Meter: 113 | Quote:
2. connect your iphone to pc lets driver install (this stpe important) 3. after that only run the patch program. 4. click install 5. select unicom 6. will pop up for enter key 7. install the patch when you phone screen prompt 8. reboot your device 9. completed | |
09-27-2013, 12:10 | #7 (permalink) |
Member: 2034932 Status: Offline Thanks Meter: 0 | Well, 1) I have installed 2) It does not install any driver...but it appears on iTunes and in My computer like "Apple usb hoster" 3-9) it does not possible to do. How can I solve the number 2? |
09-27-2013, 12:43 | #9 (permalink) |
Member: 2034932 Status: Offline Thanks Meter: 0 | That's really bad. I try also to another computer and the problem is still the same. So I can't activate the program, is there a date where everything will function? I pay for a RSim 8+ that does not function so well (because it needs patch) I buy the patch, but I can't use patch because it doesn't go... |
09-27-2013, 13:08 | #10 (permalink) | |
