08-07-2014, 22:01 | #1 (permalink) |
Major Poster Join Date: Sep 2013
Member: 2030810 Status: Offline Thanks Meter: 5 | iphone 5 T-Mobile USA has something changed in the scene ? i still have iphone 5 T-Mobile USA A1428 i got 128k sim and can only get EDGE connectivity. is there any option now to receive 3G ? iam using rsim mini+ with ios 7.0.4. |
08-07-2014, 23:37 | #3 (permalink) |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | What SIM are you using? Ok, not sure if you need to update MIni + to 10.1, but I used 9.8 and got 3G if I renamed setup.app in /applications after jailbreaking and ran the Miini + in 5S mode. I couldn't get incoming calls on 3G with TMobile(obviously, you will be using something other than TMobile), so good luck. I think it might work. Don't update to 7.1.2 yet. |
08-08-2014, 16:22 | #5 (permalink) |
Member: 1938435 Status: Offline Thanks Meter: 208 | What country though? 128K is ok. Run Mini+ or 9 Pro in 5S mode and rename setup.app. I think you need a newer Mini+ or Mini 2 though. You can also try 9 cloud + if you don't want to update the firmware yourself. Most Mini 2 are probably 9.8 now. If you don't get incoming calls, then it won't work for your SIM card. |
The Following User Says Thank You to SIMTester For This Useful Post: |
08-14-2014, 17:43 | #13 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Bangkok Thailand
Member: 830167 Status: Offline Thanks Meter: 82 | The key factor was type of sim card. 32k / 64k cut to nano sim card had completely worked fine but if usim or 128k/256k can get only 2G and edge for internet. its only my passed experience. Let try to figure out your self. good luck, |
