09-19-2014, 09:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Garhshankar,Punjab,India
Member: 1895099 Status: Offline Sonork: 100.1647265 Thanks Meter: 148 | Iphone 5C Sprint USA Unlocking Problom Plzz Help am try with rsim 9 Pro And Also try with Rsim 9 Gold . When We insert the sim and select the carrier and then restart the iphone it says activation required Am in Big trouble plzz help |
09-19-2014, 10:14 | #2 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2117665 Status: Offline Thanks Meter: 39 | You need to update you phone to IOS 7.1.2 to get it unlock through R Sim, as any R Sim Version is not able to unlock i5S/5C Sprint on 7.0.4 or lower. R Sim 9Pro and 9 Gold will not work on 7.1.2, you have to use R Sim Mini V9.8 or R Sim Air2. But i think you are too late to update you phone on 7.1.2 as Apple might stop singing 7.1.2 because IOS 8 is already out. |
09-19-2014, 19:40 | #7 (permalink) |
Freak Poster Join Date: Sep 2013 Location: United States
Member: 2033138 Status: Offline Thanks Meter: 17 | Best is to get it factory unlocked through Worldwide service as its up now or update the phone to ios 8 now and would be able to call, no data no msg...until jailbreak arrives. |
09-20-2014, 08:25 | #10 (permalink) |
Member: 2117665 Status: Offline Thanks Meter: 39 | Just update you iPhone to 7.1.2, apple still singing this version. Use R sim Mini 2 V9.8 to unlock and for Internet & SMS Jailbreak it through Pangu and install Patch A from isamteam.com repo through cydia. You will not get Incoming Call/SMS while on 3G Mode, but will works perfectly on Edge mode. |
09-22-2014, 08:17 | #12 (permalink) | |
Freak Poster Join Date: Mar 2014 Location: Heaven
Member: 2146521 Status: Offline Sonork: 100.1654013 Thanks Meter: 36 | Quote:
IT'S THE SAME **** Call distortion sometimes reduced when you lost E/3G OR while in a different state. FED UP THIS ****ING R-SIM. | |
09-23-2014, 19:48 | #15 (permalink) |
Member: 2033138 Status: Offline Thanks Meter: 17 | Best is to get it factory unlocked and then save the activation tickets so that if in case it gets locked you would be having the tickets saved and can be put again to that location to unlock the phone again but jailbreak needed for this task! |
