Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 04-10-2014, 12:32   #1 (permalink)
Member: 365715
iPhone 5S 7.0.4 (Japan) + R-Sim 9 Pro + AU KDDI = no luck
Hey all,
Anyone else here who haven't had any luck trying to activate the iPhone 5S locked for AU KDDI use?
I'm running iOS 7.0.4 and have tried IMSI 4540492 and 4407002 but the phone keeps "Searching..." for a connection.
Do I need to patch the R-Sim or do some sort of preparations in order for it to work against AU KDDI?
Looking forward to your help.
Old 04-10-2014, 12:39   #2 (permalink)
Member: 1938435
Thanks Meter: 208
No patch required. Only iRose(unlockpro.ru/nano4g) is required for service, not activation with R-SIM. Is AU KDDI in the setup menu? Do you reach the SIM not valid screen or can you actually get past the activation?
Old 04-10-2014, 12:42   #3 (permalink)
Member: 365715
iRose? Alright, I'll look into that then, I did not know about any software or anything needed for this to work.
AU KDDI is not in the setup menu no, only "Japan AU".
I can get past the whole activation but when it says that the phone will now reboot, it doesn't - I have to reboot it manually but nothing happens after that. The activation process seems to be done but I can't find any service.
But I'll look into iRose first, thanks.
Old 04-10-2014, 13:33   #4 (permalink)
futur's Avatar
Member: 2094769
Thanks Meter: 76
just the iroos tool open it and force 2g followed by a restart.
Old 04-10-2014, 14:51   #5 (permalink)
Member: 365715
Still no luck, I can't get a working connection/service regardless of whether I force 2G or 3G.
Old 04-10-2014, 15:13   #6 (permalink)
futur's Avatar
Member: 2094769
Thanks Meter: 76
back up your iphone with iTunes restore it from scratch download iroostool open it force 2g restart your iphone then inserts the chip with the sim imsi option enter kiddi code restart your iphone now you should be good to go.
Old 04-10-2014, 17:30   #7 (permalink)
Member: 1938435
Thanks Meter: 208
You need two restarts in some cases(First restart to go from No Service to carrier(no signal). Second restart to get carrier + signal).
Old 04-10-2014, 17:51   #8 (permalink)
Member: 2160880
Thanks Meter: 17
Originally Posted by ConraDargo View Post
Hey all,
the imsi code you're using are wrong, that's why you don't get signal, search in google and try all of the available imsis for au kddi
Old 04-10-2014, 17:58   #9 (permalink)
Member: 1938435
Thanks Meter: 208
I don't think it matters as long as it gets you past the Activation Required/SIM Not Valid step. There are multiple IMSIs sometimes as long as it's in the country & carrier subset.
Old 04-10-2014, 22:59   #10 (permalink)
Member: 365715
Tried 4405014 and 4405000 as well but nope, they won't work.
Guess I'll have to give the iTunes restore a go.
What a hassle -_-'
Old 04-11-2014, 09:00   #11 (permalink)
Member: 365715
*sigh* Now that I've restored my phone, the R-Sim won't work at all. The phone simply tells me that there's no SIM card inserted - unless I remove the R-Sim, then my SIM card can be detected...
Old 04-11-2014, 09:06   #12 (permalink)
Member: 2071016
Sonork: Use Skype
Thanks Meter: 13
thas mean the Rsim is broken
Old 04-11-2014, 09:49   #13 (permalink)
Member: 365715
Great... I'll just have to pay for a new one then -_-
Old 04-13-2014, 01:02   #14 (permalink)
Jennerous's Avatar
Member: 2078189
Sonork: 100.1627481
Thanks Meter: 124
I think x-sim is better than r-sim..
Sent from my iPhone using Tapatalk
The Following User Says Thank You to Jennerous For This Useful Post:
Old 04-13-2014, 08:05   #15 (permalink)
Member: 365715
Hmm really? Think that I would have a better chance of unlocking this phone with the X-sim?
I'm not exactly impressed by the R-sim so far...
Page generated in 0.24223 seconds with 8 queries
