10-31-2014, 11:20 | #1 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1970633 Status: Offline Thanks Meter: 15 | Iphone 5s activation help I have a simlocked iphopne 5s from Telus CA i try to activate it because is factory restored the phone have ios 8.x i select carrier but when restart i see again the carrier selector of rsim i select cancel but the activation say that is not the correct sim please help me |
10-31-2014, 21:09 | #4 (permalink) |
Crazy Poster Join Date: Oct 2014
Member: 2284543 Status: Offline Thanks Meter: 6 | i don't know what's wrong with you i put r-sim on my phone .. then i make restore from i tunes nothing else ! just be sure that you put the rsim in right way .. tell me what's wrong with you ? |
11-03-2014, 21:05 | #5 (permalink) | |
Member: 1970633 Status: Offline Thanks Meter: 15 | Quote:
i put the sim and r-sim then restart iphone from menu, next i select the carrier telus and select model and ios version (i have ios 8 but on the menu i can select only 7.x) then rsim tell to me that i must restart to apply settings. i select ok then restart from menu on the reboot the r-sim menu show again and tell to me: press ok to select carrier; press cancel to apply default settings. if i select ok i must select again carrier and program tell to me that i must restart if i select cancel try to activate but the iphone tell to me that the simcard is not the corect sim for activation What i can do? | |
11-03-2014, 22:14 | #6 (permalink) |
Member: 2284543 Status: Offline Thanks Meter: 6 | try to rename the bundles and use filza because i file it's not working with 8.1 for me iam sprint i did that change sprint to your carrier rename Sprint_LTE_US.bundle to Sprint_LTE_UScopy.bundle in /System/Library/Carrier Bundles/iPhone. Then find your carrier.bundle or use Unknown.bundle and rename your carrier.bundle or Unknown.bundle to Sprint_LTE_US.bundle. |
11-05-2014, 12:48 | #7 (permalink) | |
how i can do this? | |
11-14-2014, 17:16 | #10 (permalink) |
Member: 2284543 Status: Offline Thanks Meter: 6 | it happened to me .. but i try it many many time .. to put resim it was't work .. then i eject it and put it again many time until it works for me .. i really have no idea why it's not working for you |
