03-11-2020, 15:46 | #1 (permalink) |
Product Manager Join Date: Mar 2013 Location: CH
Member: 1907775 Status: Offline Sonork: 1653265:unlocker Thanks Meter: 2,693 | iPhone 6S (i5/5C/5S/6/6Plus)want to use ICCID unlock method Open Filza then Go to System/Library/Coreservices. There you will find SystemVersion.plist file. Open this file and you will find ProductBuildVersion. We need to change Value of this ProductBuildVersion to 17D50. Then go back you will find ProductVersion and we need to Change Value of this to 13.3.1 and save. Now restart your iPhone, your device shows Software Version 13.3.1 (17D50) Now you can unlock your device with ICCID unlock method. Enjoy. https://www.youtube.com/watch?v=fUdG...ture=********* Last edited by kinglock; 06-29-2020 at 05:13. |
The Following 11 Users Say Thank You to kinglock For This Useful Post: |
03-13-2020, 06:07 | #3 (permalink) | |
Freak Poster Join Date: Jul 2015 Location: Icloud
Member: 2428367 Status: Offline Sonork: 193.393.394.1 Thanks Meter: 219 | Quote:
You gave iccid no need to give other solution some secret thing should be kept private i was making good money with this but you ruined | |
03-16-2020, 12:48 | #7 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: Kumasi-Ghana
Member: 1608526 Status: Offline Sonork: 100.1611913 Thanks Meter: 60 | badman Quote:
we know this from the past on iphone 3G era................in other words fake firmware. helping each other is the aim here. | |
The Following User Says Thank You to otchere For This Useful Post: |
03-16-2020, 15:45 | #8 (permalink) |
Major Poster Join Date: Jan 2008 Location: Bangladesh
Member: 692006 Status: Offline Sonork: 1592907 Thanks Meter: 11 | After activation by ICCID, return the version and number of your firmware via jailbreak. how can change version and number. Filza not open this time. |
03-16-2020, 15:49 | #9 (permalink) |
Member: 692006 Status: Offline Sonork: 1592907 Thanks Meter: 11 | [QUOTE=shubhashish0187;14048240]After activation by ICCID, return the version and number of your firmware via jailbreak. how can change version and number. Filza not Open here |
03-16-2020, 16:53 | #10 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Quote:
manual flow Sim Not Supported ? | |
03-17-2020, 07:47 | #11 (permalink) |
Member: 1907775 Status: Offline Sonork: 1653265:unlocker Thanks Meter: 2,693 | Activation by ICCID iPhone 6, 6+ and 5s: 1.We take the phone, put the jail checkrain 0.9.8.2. 2. We go into the side and put Filza File Manager and Apple File Conduit “2” 3. Through Filza we go along the path System / Libraries / Coreservices. Copy the SystemVersion.plist file to the same folder. The file will be called SystemVersion (1) .plist 4. Open SystemVersion.plist, find ProductBuildVersion. Change the value of ProductBuildVersion to 17D50. Then we return and in ProductVersion we change the value to 13.3.1. Click save and done. 5. We reboot the device with the buttons. The download will be long, with a running status bar. 6. After loading the device, insert the sandwich and enter the current ICCID in the drop-down menu. 7. We go through the activation and we have a fully functioning device. (will not work without a gasket) Now return the firmware version: 1. We take the phone, again we put the jail checkrain 0.9.8.2. 2. Thanks to the Apple File Conduit “2” tweak installed earlier, we connect the phone to any program (iTools, 3Utools, etc.) and go to the “File System” section. 3. In 3Utools, as an example, we go along the path System / Libraries / Coreservices. Delete the SystemVersion.plist file and rename the previously copied source file named SystemVersion (1) .plist to SystemVersion.plist. That is, without "(1)". 4. We reboot the device with the buttons. The download will be long, with a running status bar. That's all. The phone remains on the old firmware 12.4.x and works as a non-wizard. After all the manipulations, all applications work stably, both old and just installed. |
The Following 10 Users Say Thank You to kinglock For This Useful Post: |
03-17-2020, 13:12 | #12 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Quote:
03-18-2020, 14:55 | #15 (permalink) | |
Member: 692006 Status: Offline Sonork: 1592907 Thanks Meter: 11 | Quote:
The Following 3 Users Say Thank You to shubhashish0187 For This Useful Post: |
