Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & SAM SIM
Old 05-17-2018, 04:10   #1 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 1,812
May 17 ICCID 89014103279529155609
The Following 4 Users Say Thank You to kinglock For This Useful Post:
Old 05-17-2018, 04:12   #2 (permalink)
Member: 2837916
hi pals muther****er **** yall
Old 05-17-2018, 05:05   #3 (permalink)
Member: 1907775
Thanks Meter: 1,812
How to unlock by rsim12 select "14 "
https://www.youtube.com/watch?v=d5P9...ture=*********
V9.6.5 plug and play, How to update r-sim 12by dongle
http://forum.gsmhosting.com/vbb/f819...ongle-2309321/
Old 05-17-2018, 05:41   #4 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,663
tested by me
big thanks
Old 05-17-2018, 07:42   #5 (permalink)
rajesh_ch's Avatar
Member: 618404
Sonork: 100.1624568
Thanks Meter: 283
handset activated but show no service
Old 05-17-2018, 11:18   #6 (permalink)
Member: 2117988
Sonork: 100.1667932
Thanks Meter: 41
Is the previous one working or it’s block,king?
Sent from my iPhone using Tapatalk
Old 05-17-2018, 21:33   #7 (permalink)
Member: 1334699
i had the same problem and i had to reset the network and begin and begin again when you input *5005*7672*00# and edit iccid 89014103279529155609, then again input *5005*7672*00# i only errase "#" and write again and send, it shows the menu and select the original company and it shows another menu, choose the first option and it works, but careful, i had same problem with only one iphone i try with a lot of r-sim, but it doesn´t work and the problem was the CHIP it´s only a tip i changed the chip and it works, another tip is when i put the first time the CHIP with the r-sim in the iphone!, it has to show signal if it shows the signal then you should try to continue.
Good Luck
Old 05-23-2018, 20:40   #8 (permalink)
Member: 2801896
Thanks Meter: 2
New ICCID?
Page generated in 0.30549 seconds with 7 queries
