09-20-2013, 00:03 | #1 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2029609 Status: Offline Thanks Meter: 2 | R sim8+ Iphone 5 Sprint to AT&T I began by inserting the Rsim with the new ATT nano sim and telling it the new carrier would be att but now it doesn't recognize it as valid. I must be doing something wrong. I tried the patch and it installed the rose program but when i press on the app it never executes, it just starts and kills itself. Any help would be great. Carlos |
09-20-2013, 02:17 | #5 (permalink) |
Member: 2029609 Status: Offline Thanks Meter: 2 | Ok, So let me get this right,
Then what do I do? Do I put in the AT&T sim just like normal or do I need to run the patch first? |
09-20-2013, 14:33 | #6 (permalink) |
Member: 2029609 Status: Offline Thanks Meter: 2 | Ok, So now I am confused, I tried a new sim and selected sprint like mrfixit suggested and now it seems to be back to thinking it is a Spint iPhone again and it still wont recognize the new att sim. WTF am I doing wrong. Super Frustrating, Also does this mean i need yet another sim. |
09-21-2013, 11:23 | #11 (permalink) |
Member: 2029609 Status: Offline Thanks Meter: 2 | Ok, So can I just clarify some things because i seem to be confused. During a normal installation I want to take the rsim insert it with my new nano sim, one for the provider I want to to use. Then I want to select the model of phone and then tell the program what carrier I want to use, or do I tell it the carrier that it was previously locked to as mrfixit implies? After that it will install and then I restart the phone, do I take out the rsim at this point and just put the same nano sim from the new provider in by itself and it should activate, or do I have to download the patch first and then it will activate? or do i activate it somehow with the rsim still installed? Because that is pretty much what i did the first attempt but when i inserted the new provider sim it tells me that it is not valid, even though it says that the carrier is now att. I was however not able to run the patch the first time it would just kill itself after a second of running. I was able to run it the second time but now it seems to be running back on the sprint network so thats not very helpful, and i have no way to verify it. I think I am close, I just seem to be missing a step somewhere. |
09-21-2013, 19:18 | #12 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | I tried 4 different r-sim 8+ with this sprint iphone 4s and use 64k sim cut to nano and always cannot see sim, message: no sim but phone can see bigger micro sim please explain if I need patch to make rsim 8+ work with this 64k normal sim card? |
09-21-2013, 21:09 | #13 (permalink) |
Freak Poster Join Date: Mar 2010 Location: Dubai
Member: 1267526 Status: Offline Sonork: 100.1619624 Thanks Meter: 73 | @ laxbograt Okay this is what you do 1- Insert At&t sim with R-Sim in the phone 2- Select Type of Phone (iphone 4S or iPhone 5 ) 3- Select Carrier to which the phone is Locked to NOT the Carrier you want to use (In your case i think you are using a Sprint phone and At&t Sim Card - So you will select Sprint) 4- Accept 5 -Turn Phone Off 6- Turn phone back ON 7- Activate if needed and you will get Signal ( Remember the R-Sim and At&t Sim stays in the phone all the time and in future as well ) 8- If needed Install Patch to get 3G Hope this helps |
The Following User Says Thank You to hassanlakhani For This Useful Post: |
09-23-2013, 19:56 | #15 (permalink) |
Member: 2029609 Status: Offline Thanks Meter: 2 | Ok, Update time, I have successfully gotten the phone to make calls & make and recieve txt messages, however I don't get any carrier data services, it has the e for edge but it says "could not activate cellular data network" when every i try to use it. Any suggestions I tried the irosetool patch and it appeared to work but still no luck. |
