Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 07-22-2014, 04:43   #61 (permalink)
Member: 2117377
Thanks Meter: 7
i tested heicard v7.4 and rsim 9.8, everything ok :
-sms in, out - ok
-imcoming call, outcoming call - ok
-ft, imesss, - ok
-3G, 2G - ok
- but when i lost singal , it doesn't automatic get singal . i must kick singal ( 15second )
i live in Ho CHi Minh city, Vietnam .
Old 07-22-2014, 10:51   #62 (permalink)
Temporary banned !!
Member: 2127068
Thanks Meter: 51
-sms in, out - ok
-ft, imesss, - ok
-3G, 2G - ok
Any special patch that you installed?? Can i please have the stepts you used to make internet work?
Enviado desde mi iPhone utilizando Tapatalk
Old 07-22-2014, 16:56   #63 (permalink)
Temporary banned !!
Member: 2127068
Thanks Meter: 51
I found this online, has anyone tried?
solve imassage Facetime SMS INTERNET problem on Sprint iphone 5
Finally every thing work ip5 sprint , here is the steps:
1- jailbreak
2- install ifile
4- open ifile and go to system/library/carrier bundles/iphone/carrier lab.bundle
3. delete file 310120 and all sprint.bundle (Sprint_LTE_US.bundle and Sprint_Vigin_US.bundle)
5- rename carrier_lab.bundle into Sprint_LTE_US.bundle.
6- go to var/wirless/library then search in evey folder and delte all .plist in evray wher in the folders.
7- reboot , first put your original sim without r-sim after that with r-sim , reboot many times
8- after reboot go to settings and enable data roaming and APN
Old 07-23-2014, 03:28   #64 (permalink)
Member: 2184212
Thanks Meter: 19
1- jailbreak
2- install ifile
I already tried almost the same step above
first time okay but later on I lost my E and the same step still hide my E/3G
why wait somebody to try, go try yourself
Old 08-15-2014, 02:54   #65 (permalink)
Temporary banned !!
Member: 2127068
Thanks Meter: 51
Can the R sim Air 2 be upgraded to the 10.1 version of R Sim Mini 2?
Old 08-22-2014, 16:38   #66 (permalink)
Member: 2117331
This patch from sidya messed up my network I couldn't even talk to nobody anymore
Old 08-22-2014, 16:50   #67 (permalink)
Temporary banned !!
Member: 2127068
Thanks Meter: 51
Same thing happened to me a few times, you will have to restore your phone in itunes and start the process all over again
Old 09-30-2014, 00:24   #68 (permalink)
Temporary banned !!
Member: 2127068
Thanks Meter: 51
Is the R Sim 9 + nano cloud compatible with 256K sim cards ??
Old 09-30-2014, 07:10   #69 (permalink)
Finn's Avatar
Member: 7731
Thanks Meter: 27
Yes it is fully compatible and it also supports 4g, sometimes 5g as well (in case you didn't get your answer the previous 20 times you asked/spammed)
Old 10-09-2014, 05:22   #70 (permalink)
Member: 2197847
Thanks Meter: 12
Are you using automatic network selection or manual??? If using automatic, switch to manual and select your network from the list. Toggle mobile data and data roaming but do not toggle enable 3G if you intend to use only 2g internet, toggle enable 3G otherwise. You should be getting internet by now.
Page generated in 0.16522 seconds with 8 queries
