07-22-2014, 04:43 | #61 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2117377 Status: Offline Thanks Meter: 7 | -sms in, out - ok -imcoming call, outcoming call - ok -ft, imesss, - ok -3G, 2G - ok - but when i lost singal , it doesn't automatic get singal . i must kick singal ( 15second ) i live in Ho CHi Minh city, Vietnam . |
07-22-2014, 10:51 | #62 (permalink) | |
Temporary banned !! Join Date: Feb 2014
Member: 2127068 Status: Offline Thanks Meter: 51 | Quote:
Any special patch that you installed?? Can i please have the stepts you used to make internet work? Enviado desde mi iPhone utilizando Tapatalk | |
07-22-2014, 16:56 | #63 (permalink) |
Member: 2127068 Status: Offline Thanks Meter: 51 | I found this online, has anyone tried? solve imassage Facetime SMS INTERNET problem on Sprint iphone 5 Finally every thing work ip5 sprint , here is the steps: 1- jailbreak 2- install ifile 4- open ifile and go to system/library/carrier bundles/iphone/carrier lab.bundle 3. delete file 310120 and all sprint.bundle (Sprint_LTE_US.bundle and Sprint_Vigin_US.bundle) 5- rename carrier_lab.bundle into Sprint_LTE_US.bundle. 6- go to var/wirless/library then search in evey folder and delte all .plist in evray wher in the folders. 7- reboot , first put your original sim without r-sim after that with r-sim , reboot many times 8- after reboot go to settings and enable data roaming and APN |
07-23-2014, 03:28 | #64 (permalink) | |
Freak Poster Join Date: May 2014
Member: 2184212 Status: Offline Thanks Meter: 19 | Quote:
first time okay but later on I lost my E and the same step still hide my E/3G why wait somebody to try, go try yourself | |
09-30-2014, 07:10 | #69 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Chalkidiki/Greece
Member: 7731 Status: Offline Thanks Meter: 27 | Yes it is fully compatible and it also supports 4g, sometimes 5g as well (in case you didn't get your answer the previous 20 times you asked/spammed) |
10-09-2014, 05:22 | #70 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2197847 Status: Offline Thanks Meter: 12 | Are you using automatic network selection or manual??? If using automatic, switch to manual and select your network from the list. Toggle mobile data and data roaming but do not toggle enable 3G if you intend to use only 2g internet, toggle enable 3G otherwise. You should be getting internet by now. |
