Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 04-23-2014, 00:57   #61 (permalink)
futur's Avatar
Member: 2094769
Thanks Meter: 76
It does not have a stable signal it's totally failure for ios 7.1 for the usa carreirs.
Old 04-23-2014, 01:12   #62 (permalink)
Member: 2160880
Thanks Meter: 17
Originally Posted by tilingas View Post
I did the same, tried with a 5s from att ios 7.1, iphone 5s telcel ios 7.06 and same sh...it, goes to activation screen, insert a valid sim card, blah blah blah.......
did you try with the new videos posted in the forum ?
there are 3 of them, 1 is for t-mobile 7.1 and supposed to work, we haven't had the chance to test it, probably tomorrow
Old 04-23-2014, 01:24   #63 (permalink)
futur's Avatar
Member: 2094769
Thanks Meter: 76
Yes I did and the signal was not stable and based on that I can't give it to my customers.
Old 04-23-2014, 09:05   #64 (permalink)
Member: 1767456
Sonork: 1621131
Thanks Meter: 62
Atm - only Heicard Fixed Activation Issue so who's the 1st one ?
Who's best one ?
I already updated to Heicard 7.3
Old 04-23-2014, 10:40   #65 (permalink)
Crazy Poster
Member: 2157572
Thanks Meter: 10
Who's best one ?
Working good and with 3G?
Old 04-23-2014, 14:27   #66 (permalink)
Member: 1895857
Thanks Meter: 10
Should be new firmware update within day or two for Mini 2 I hope after that evrything will work smooth.
Old 04-23-2014, 14:57   #67 (permalink)
Member: 1288185
Thanks Meter: 74
R-sim Mini2 V9.5 is available...
Testing it NOW....
The Following User Says Thank You to ashish_beri For This Useful Post:
Old 04-23-2014, 15:14   #68 (permalink)
Member: 2089201
Thanks Meter: 7
Active code
Testing it NOW....
Hi, from where do we get "active code " for updating R-Sim mini 2.
They have mentioned 1 update is free.. Please help
Old 04-23-2014, 15:45   #69 (permalink)
Member: 2173536
Originally Posted by b7ack007 View Post
hi, from where do we get "active code " for updating r-sim mini 2.
Только что прошил на 9,5 старым кодом
Кто напишет нормальную инструкцию? Не могу поставить, постоянно выкидывает в активацию
Old 04-23-2014, 16:04   #70 (permalink)
Member: 1895857
Thanks Meter: 10
Not working same story… 128k and 256k still switching to original carrier
Old 04-23-2014, 21:31   #71 (permalink)
Member: 1895857
Thanks Meter: 10
Find a solution how to run 128k and 256 cards with v9.5 firmware.
1. Install rpatch and turn it on (in other way 3G but no incoming calls)
2. put R-SIM with Your card and select network
3. Eject simcard
4. Erase network settings wait until phone reset and power on…
5. Enter Settings and insert R-SIM with Your card
6. Turn off network and 3G (LTE) or anything else
7. Wait for signal
8. Make a test call and after disconnect open rpatch and turn it off and on (You must do it quick in other way phone switch network to simcard)
9. After while turn on mobile data and data roaming only EDGE but incoiming calls work OK
10. Download APN from Unlockit - APN Changer for your iPhone
11. Enjoy
Old 04-23-2014, 21:32   #72 (permalink)
Member: 1767456
Sonork: 1621131
Thanks Meter: 62
Smile
Didn't test yet but i think this problem will remain !
Anyway - i don't have atm any handset for test ...
But i know that Chinasnow aka Heicard - will try do best for solve all problems
Old 04-23-2014, 23:13   #73 (permalink)
Member: 2160880
Thanks Meter: 17
3. Eject simcard
7. Wait for signal
11. Enjoy
how much time is "After while" ?
thanks,
Old 04-23-2014, 23:30   #74 (permalink)
futur's Avatar
Member: 2094769
Thanks Meter: 76
I just test it and still no go, I really can't believe the rsim people with this stupid new product called rsim mini2 since it was supposed to work on the ios 7.1 when it's a totally none functional item. is it to get the people money well that was not a smart move since they are tarnishing their reputation and for an example I got 100 cards and all of them will be returned to the seller so where is the benefit other than tarnishing their reputation.
Old 04-23-2014, 23:57   #75 (permalink)
Member: 2160880
Thanks Meter: 17
True. And totally 1000% agree. We bought 200 pcs. We will return them as well...
Page generated in 0.23008 seconds with 8 queries
