09-15-2013, 17:45 | #1 (permalink) |
Major Poster Join Date: Jul 2013 Location: US
Member: 1984671 Status: Offline Thanks Meter: 8 | "No service" solution for sprint iPhone 5 I recently found how to fix no service issue in locked sprint iphone 5. Here is my story: I got two sprint iphone unlocked to any GSM network in US but it always took me hours (3-4 hours) to get it unlocked. I always wonder why it take so long because I got "no service" many times. I found that it is due to the fact that I left "CELLULAR ON" before restarting after patching it. So now I got them unlocked right away in the first time if I do following Rsim instructions AND 1) After patching it. 2) Go to "Setting" --> Cellular ---> Turn off Cellular 3) Put your sim and Rsim 4) Restart After I found this trick, I also tested the procedure that I left Cellular ON. Then you know, I got "No service" Everything else should be same as Rsim instructions. Hope it helps. BR |
09-18-2013, 00:16 | #2 (permalink) | |
Junior Member Join Date: Sep 2013
Member: 2026406 Status: Offline Thanks Meter: 2 | Quote:
can u explain step by step because i am getting same problem . with rsim and sim inside i ge the signal then i patch get 3g but when restarting iphone keeping getting no service . thx | |
09-18-2013, 20:58 | #3 (permalink) | |
Member: 1984671 Status: Offline Thanks Meter: 8 | Quote:
Restart your phone You should see bar signal Then go to Setting, Cellular --> ON to see 3G or Edge Mine never get 3G. This is to help you getting SIGNAL only. 3G issue should be solved by Rsim team. | |
