03-06-2015, 01:03 | #1 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2017675 Status: Offline Sonork: denden0608 Thanks Meter: 0 | Problem rsim 9pro on iphone 5s ios7 |
03-06-2015, 13:59 | #3 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Pakistan Age: 26
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | R-SIM 9 PRO ONLY SUPPORT 5C And 5S ON IOS 7.0.4 OR BELOW IF UR VERSION IS HIGH THEN USE R-SIM AIR 2 IF UR VERSION IS 7.0.4 OR BELOW THEN TRY WITH OTHER CARD. |
The Following User Says Thank You to masterRt1994 For This Useful Post: |
05-04-2015, 02:33 | #8 (permalink) |
Junior Member Join Date: May 2015 Location: Brazil
Member: 2388682 Status: Offline Thanks Meter: 1 | I was going to create a new thread about the problem that I am having but I found this thread.. Here it goes.. I have an iPhone 5s iOS7 that is originally from T-Mobile.. I bought this device from someone who told me that it worked for him using the Air2 sim but he no longer had it.. so I got this Air2 mini from a friend and when I insert the simcard into the phone it gives the menu to select the carrier.. HOWEVER, it only gives me about 6 seconds before the white screen with the apple logo shows up and locks my phone.. when I unlock the device I get this menu that says ACTIVATION required and then I get the SIM NOT VALID message. When I insert the simcard without the Air2 I am able to see the dots as for the signal but again I get the activation required message. ALSO, sometimes it says- phone activated with cdma network. for roaming enter a simcard. What can i do in this case beside factory unlocking the device. Id really appreciate your help. Last edited by Landorod10; 05-04-2015 at 02:37. Reason: iOS 7.1 |
