10-24-2015, 15:27 | #1 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2344331 Status: Offline Thanks Meter: 0 | R-sim 10 for iPhone 6 ATT USA: "no service", no signal |
10-26-2015, 02:54 | #2 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1958033 Status: Offline Thanks Meter: 1 | First check inside "Cellular" if LTE is enabled. In case of, disable it and check if gets signal. If isn't working try "Reset Network Settings". It's located inside Settings > General > Reset. And then disable again LTE inside Cellular. Post your results |
10-26-2015, 19:12 | #3 (permalink) |
Member: 2344331 Status: Offline Thanks Meter: 0 | Thanks for your answer! Iīm trying all you said, but there is no way to get signal from my carrier. I choose 2G-3G option on R-sim menu, so I donīt know if there is any problem or R-sim doesnīt work as they said. |
