01-13-2014, 09:40 | #61 (permalink) | |
Insane Poster Join Date: Aug 2009
Member: 1090048 Status: Offline Sonork: dinidu Thanks Meter: 10 | Reply Quote:
Insert sim, restart, Add isamteamcom to your cydia source, install "A:R-sim ios 7 5s/5/5c ...." patch, then open safari, go to rsim5/nano4g, install iRoSeTool, after install done, open iRoSeTool, set Force 3g, wait for the signal, Celluler data: ON , Unlock done with 3G/LTE. Note: Work only with cutsim. won't work with 128k sim! Hit Thank if this help to you! | |
01-13-2014, 09:42 | #62 (permalink) |
Member: 1090048 Status: Offline Sonork: dinidu Thanks Meter: 10 | EVERYONE TRY THIS Jailbreak your device, Insert sim, restart, Add isamteam.com to your cydia source, install "A:R-sim ios 7 5s/5/5c ...." patch, REBOOT, then open safari, go to rsim5.com/nano4g, install iRoSeTool, after install done, open iRoSeTool, set Force 3g, wait for the signal, Celluler data: ON , Unlock done with 3G/LTE. Note: Work only with cutsim. won't work with 128k sim! Hit Thank if this help to you! |
01-13-2014, 13:27 | #63 (permalink) | |
Junior Member Join Date: Jul 2004 Location: Colombo, Sri Lanka Age: 49
Member: 73854 Status: Offline Thanks Meter: 1 | Quote:
01-13-2014, 19:53 | #66 (permalink) |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | Can you please screen cap your phone with settings general about to show IMEI, so we know it's not factory unlocked? I have never seen LTE appear with R-SIM, only E & 3G/4G with 64K cut SIMs. |
01-15-2014, 01:17 | #67 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2104627 Status: Offline Thanks Meter: 0 | ive tryed every way nothing seems to work with my 4s using r-sim 8+ keeps asking for activation when i get it to say o2 as carrier then says invalid sim so then i have to put my orange sim back in Last edited by st1ggy; 01-15-2014 at 01:26. |
01-15-2014, 03:30 | #68 (permalink) |
Member: 1938435 Status: Offline Thanks Meter: 208 | You need to choose the original carrier of the phone(Sprint/Verizon/AT&T, etc.), and then you should either see No Service(if your SIM is too newer) or Carrier + 3G. If you're running a GSM phone. If it's Sprint/Verizon, you need to jailbreak. |
01-28-2014, 08:56 | #71 (permalink) |
Member: 2102093 Status: Offline Thanks Meter: 0 | How to check what kind of sim card i have? I try with nano sim and no 3g I replace sim card (this is sim card which can be change to micro sim) and no 3g I don't think that my MNO have different cards? Is there is any way check that card is 64k ? |
