10-30-2013, 10:06 | #1 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2051555 Status: Offline Thanks Meter: 0 | R-SIM 8 Ir0setool no 3G!! please help I have iphone 5 locked to Orange UK I am using Czech Republic MOBILCZ network When I was using Vodafone network I had normaly 3G but my mobile didnt recognize MOBILCZ simcard I installed Ir0setool ... after that MOBILCZ worked perfectly but no 3G not even for VODAFONE! just EDGE (So I suposse ir0setool must be the cause) Can u help me somehow? The application is in korea language |
10-30-2013, 11:51 | #2 (permalink) |
Junior Member Join Date: Sep 2005 Location: Poland
Member: 183938 Status: Offline Thanks Meter: 5 | Hello, I'm also using iPhone 5 from orange uk but in Poland. It depends what sim card you are using. Some cards don't need to use patch, mostly these are 64k standard sim and micro sim. All nano simcard are not compatible with r-sim and you need to install ir0se patch to make it work. You can try replace your MOBILCZ simcard to standard sim or micro sim and cut it to nano. ir0se tool forces iPhone to work only edge. You can try to disable it. Just run ir0se app then select button at the top. After that you will have 2 options first one is to enable patch and second to disable patch. After you disable patch you will have 3g on VODAFONE but MOBILCZ will not work. |
10-30-2013, 19:34 | #10 (permalink) |
Member: 2051555 Status: Offline Thanks Meter: 0 | So why the fu** they have it like solving problem for 3G GSM cards if its not working? :X Do you know any kind of progress? If they are working on or its not possible with current R-SIms and they need jailbreak or something ? |
10-31-2013, 01:06 | #11 (permalink) | |
Freak Poster Join Date: Oct 2006
Member: 379713 Status: Offline Thanks Meter: 55 | Quote:
Progresss? What progress? This RSIM team have the most terrible support then the other sim interposer. Just read another thread in this subforum,and see how many times the product supporter showed up. In this "support forum" all we can do is help each other with almost no support from the product supporter itself... | |
The Following User Says Thank You to ogel2 For This Useful Post: |
