01-02-2014, 22:54 | #1 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2097618 Status: Offline Thanks Meter: 0 | R-sim 9 pro not working on my iphone 5 locked to vodafone! my iphone 5 version 7.0.4 carrier: vodafone UK 5.6 im trying to use r-sim 9 pro with my swedish card called tele2 please help |
01-03-2014, 09:55 | #3 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2088543 Status: Offline Thanks Meter: 1 | 1-Jailbreak your Iphone 2-go to Cydia Add Source "cydia.china3gpp.com" 3-Install "Ιphone 5 IOS7 NanoGpp" path and "E:CommCenter*Path" 4-After Reboot Open Safari www.rsim5.com/nano4g, after that, please click “GO”, and then click “Free Installationm/nano 5-Open Irose path 2G Done |
The Following User Says Thank You to aston23 For This Useful Post: |
01-03-2014, 17:03 | #6 (permalink) |
Insane Poster Join Date: Nov 2013
Member: 2072782 Status: Offline Thanks Meter: 12 | Are u sure it is locked on vodafone? Mine was supposed to be locked on O2 ( seller told so) but finally it is on vodafone. |
The Following User Says Thank You to fotiskam For This Useful Post: |
01-03-2014, 17:55 | #7 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1549748 Status: Offline Thanks Meter: 0 | mine does not work too phone is locked to verizon...everytime i put in the imsi number of my carrier a want to use i have to make a reboot..after reboot i will get short connection to my carrier for about 1-2 seconds...and after that the iphone says that he needs an activation but with the original sim from the original carrier...everytime it needed this activation...the carrier i want to use is o2 germany.... any know what to do? |
01-03-2014, 22:20 | #9 (permalink) |
Member: 2072782 Status: Offline Thanks Meter: 12 | Ok, lets take it from start. 1. When vodafone sim is inserted everything works. 2. Remove sim , then phone still works but without sim. 3. When another sim is inserted after some seconds it should ask to activate but will not accept the activation 4. Then insert rsim together with your sim. 5. A menu should appear, choose i5 , input imsi, Type 2341590, click ok. Do it fast. You have to click ok 6. Then hold power button , close device. 7.open device. It maybe ask you to activate, connect to a wifi and click next, it should activate ok. 8. After that you maybe show no service. If so, install nano 3g patch, click force 2g, reboot , and after that it should be ok. |
01-04-2014, 17:20 | #10 (permalink) |
Member: 2097618 Status: Offline Thanks Meter: 0 | already tried the method above always get stuck on step 5 no menu appears and when i try manually to go into setting and then into sim applications the phone locks. what should i do? |
01-04-2014, 18:07 | #11 (permalink) |
Member: 2072782 Status: Offline Thanks Meter: 12 | Do you have any other sim card? If not just insert the vodafone sim with rsim , it is the same. When changing sim the menu MUST appear. If not, something is not OK... As I can understand, It seems rsim has "locked" a carrier different than the one it should lock. |
01-04-2014, 18:44 | #12 (permalink) |
Member: 2097618 Status: Offline Thanks Meter: 0 | thanks fotiskam i tested the rsim with the vodafone sim and then after with my normal sim and it worked but now i get no service. But i dont understand how to use the r-sim carrier patch tool i get activate code verify failed |
01-04-2014, 19:51 | #13 (permalink) |
Member: 2097618 Status: Offline Thanks Meter: 0 | i have new problem now. The old problem where menu didn't come up is fixed. The new problem is that i've entered 3 different imsi Numbers, 2400700,2400782 and 2400785 these didn't work. i need imsi for tele2/comviq. The problem now is that menu comes up i choose i5 the other carrier and type in the imsi number i later get locked and it says sim card not valid. |
01-05-2014, 02:13 | #14 (permalink) |
Member: 2072782 Status: Offline Thanks Meter: 12 | Read carefully my steps bro. You only need 1 IMSI. This is the IMSI of the carrier your phone is locked to, in your case "vodafone uk" , which is 2341590. You will never need another IMSI. Whatever sim u use it doesnt matter. The IMSI will always be 2341590. ( the reason is simple, your phone needs to have a vodafone uk sim in to work. by typing this code, the rsim acts like being a vodafone uk sim ) After that you may have no service. This is ok , and most of the times is fixed by the iR0se patch. What you have to do: 1. Do the steps to get to "no signal" condition. 2. Connect iphone to wifi 3. Click safari and Go to this address http://www.rsim5.com/nano4g 4.click install now 5. Accepted whatever it asks to 6.you should see iRosetool on the home screen, click on that 7. Click force 2g, it should say patch ok. 8. Restart device 9. Check signal. It should be ok 10. To fix internet connection of your sim card first enable " data roaming" on settings. Then go to http://unlockit.co.nz choose create apn and now choose your current carrier ( tele ) |
