R-Sim adn Iphone XS Max Hi, please if somebdy shows me how can i put rsim on new simcard holder of Iphone XS Max, because i cant make it work...please with some pictures, i was thinking on some glue :D:D , but i ask first of all if somebody have a better idea |
get an old deactivated sim and glue the rsim together with it, then you can insert it as one piece, and activate with iccid, then insert your real sim |
I actually never thought of doing that lol I just grabbed some thin double sided tape I had lol. Sent from my iPhone using Tapatalk |
i think the double tape its best ;) |
So tape or glue is the the only way? Thanks |
Pls post photo of it lol |
It’s not hard just take a small piece of double side tape and stick it to the middle of the Rsim then stick to sim Sent from my iPad using Tapatalk |
Does it mess up of the metal contacts if you put the tape in the middle? |
Nope once ur done remove the Rsim clean with some rubbing alcohol to remove the tape Sent from my iPad using Tapatalk |
I had issues with my old r sim where it pulled the metal of the little square in the middle. That little metal square doesn’t do anything. Correct. Just the metal prongs on each side |
R-Sim adn Iphone XS Max Quote:
Oh if it pulled that out u probably need a new rsim because that is the chip itself that program's I believe.. u gotta be very careful because the Sim slot in the Xs Max is very narrow..my old rsim the black on the back got scraped and ruined the rsim..had to get a new one this time I made sure to be extra careful and slow when removing and inserting into the Xs Max. Here are photos for those that asked https://uploads.tapatalk-cdn.com/201...94ab19ed53.jpg https://uploads.tapatalk-cdn.com/201...3858ac6c85.jpg https://uploads.tapatalk-cdn.com/201...f8efea3c0c.png https://uploads.tapatalk-cdn.com/201...a95c789b59.png Sent from my iPhone using Tapatalk |
You’re piece of tape is on top of the square I’m talking about. So I assume as long as careful. It’s fine |
Yes just be careful cause rsim is very fragile and the max slot is a little bit more narrow so it barely fits if the rsim shifts while inserting use ur fingernail to guide it in the slot. Sent from my iPhone using Tapatalk |
Awesome. I’ll try now. Thanks |
