05-12-2014, 18:36 | #1 (permalink) |
Junior Member Join Date: May 2014
Member: 2184813 Status: Offline Thanks Meter: 0 | R-SIM Air 2 - iPhone 5S - Activation error - Invalid Sim Please help to install R-Sim Air 2 have iPhone 5s (model A1453) with factory simlock Sprint USA, and the card that I want to use the R-SIM comes with Polish PLAY. When I put the R-SIM card pops up a window, and choose from a list of available networks Sprint USA, then gets info about resetting the phone. After this operation, after turning my phone instantly activation window pops up and the message "Invalid Sim Card". I've tried the "iRose Tool" enable the option "Force 2g" Unfortunately, nothing helped. I tried also enable the option "Force 3g" but getting the message "Patch Closed". Maybe I should install rPatch? Does it help with my problems with activation? Please help and have any explaination step by step what I should do. Thanks in advance for your help! |
05-13-2014, 06:43 | #2 (permalink) | |
Product Manager Join Date: Sep 2003 Location: Enugu - Nigeria Age: 59
Member: 38751 Status: Offline Sonork: 100.75985 Thanks Meter: 2,573 | Quote:
hope you have a great day. | |
05-14-2014, 18:02 | #5 (permalink) |
Freak Poster Join Date: May 2014 Location: INDIA
Member: 2184652 Status: Offline Thanks Meter: 103 | steps by indian reseller The steps are easy.. 1 turn off cellular data and 3g and everything in cellular.. 2 insert sim and rsim and select carrier and accept message then restart.. 3 quickly go to settings when phone turns on and make sure that cellular is turned off.. 4 if you have sprint then you dont need rpatch but if you have any other carrier you need a rpatch installed. But the twist here is that only activation code in rpatch must be inserted and the toggle to enable the patch must be turned off (This must have been the first step) 5 now your phone must return you with a activation required screen . This is normal. 6 Quickly restart and when your phone boots up quickly go to irose and click on force 3g ( clicking on force 3g can also be done before inserting the rsim in step one) 7 Now you must have signals . 8 Now go to cellular data and turn on everything ( required for incoming calls and sms) 9 If this doesn't work for you then you can try all this in force 2g mode If found with rsim air 2 sprint is almost giving 99% stable signals but with other carriers its giving like only 60% |
05-16-2014, 06:08 | #9 (permalink) |
Major Poster Join Date: Mar 2014
Member: 2157248 Status: Offline Thanks Meter: 1 | Tried to install the rpatch rsim5com/rpatch on top of the irose 1.1 to get Data for either 3g But I keep getting "Error Please check your code" by getting the code and scratching off on the back of the package. Please help!!!! |
05-18-2014, 08:31 | #11 (permalink) |
Member: 2157248 Status: Offline Thanks Meter: 1 | Ok understand already! Now I have activation error on 5s sprint 7.1.1. And unlock by this card no stable. It work but network sometimes knocks activation Отправлено из моего iPhone используя Tapatalk |
05-31-2014, 11:41 | #12 (permalink) |
Member: 2184652 Status: Offline Thanks Meter: 103 | R-SIM Air 2 - iPhone 5S - Activation error - Invalid Sim V9.8 update test Sent from my iPhone 5s using Tapatalk pro Last edited by SmartSamrat; 05-31-2014 at 11:52. |
06-01-2014, 08:10 | #14 (permalink) |
Member: 2184652 Status: Offline Thanks Meter: 103 | I register my meid and iccid of sprint sim in sprint database now my sprint sim showing invalid sim Now i insert rsim air2 with local airtel carrier. Now i able to send sms and use 2g fine. Sent from my iPhone 5s using Tapatalk pro |
