03-31-2014, 18:33 | #16 (permalink) | |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | Quote:
Bad ESN or clean ESN is irrelevant for you because you are outside the USA and have a 2G 64K SIM. It will create valid activation tickets. I need to double check these Verizon GPP SIMs to show if they switch the default to Carrier 16.0 on iOS 7.1 Verizon. They do not work with 128K SIMs, so I stopped ordering them and was just using the reset SIM on the Sprint GPP chips for Verizon-locked iPhones. The Sprint GPP firmware is definitely newer though. | |
04-01-2014, 01:52 | #18 (permalink) |
Member: 1938435 Status: Offline Thanks Meter: 208 | No, R-SIM Air doesn't support picture messaging on any iOS without a jailbreak or AT&T iPhone 4S. Sprint 4S is 100% working with GPP(7.9) & 64K SIM including picture messaging. With 128K SIM, you need valid activation tickets from Sprint on 7.1 and iRose tool(unlockpro.ru/nano4g), regardless of GPP version or R-SIM Air. |
04-01-2014, 04:26 | #19 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2094769 Status: Offline Thanks Meter: 76 | Well rsim air does support picture messaging even without jailbreak and all you need to do is to add your mms information for that carrier your are using in that section called cellular date with the only difference is that without jailbreak you will not be able to add the 3g patch from the isam source and force the 3g in iroostool but you will get only 2g but even though with the 2g you still be able to send picture messaging even if the speed is slow and I have done hundred and hundred of those so in my opinion rsim air is the champion for iphone 4s. |
04-01-2014, 07:34 | #21 (permalink) | |
04-01-2014, 15:55 | #23 (permalink) |
Member: 1938435 Status: Offline Thanks Meter: 208 | You have a 64K 2G SIM. You can use GPP or Gevey from iOS 6 and still get SMS/2G with iRose tool from unlockpro.ru/nano4g on any iOS including 7.1. |
05-31-2014, 03:40 | #24 (permalink) |
Junior Member Join Date: May 2014
Member: 2196328 Status: Offline Thanks Meter: 0 | RSIM Air Verizon iphone 4s to Straight talk I have been fighting with this rsim for a few days now, I could really use some help! Ive been poking around in here and haven't seen anything like my problem so here it goes... I succesfully got the phone to show "TFW 16.0" Instead of the Verizon 15.0 it was showing before.... but now the phone number is listed as unknown and is forever searching. Any input is greatly appreciated! Ready to smash this phone if it doesnt work soon -__- |
