03-23-2014, 16:44 | #452 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2094769 Status: Offline Thanks Meter: 76 | That is true since you don't have the option to add the sms on the ios 7.1, so now you need for a jailbreak to come out for the ios 7.1 so you can add the source for the editing sms. |
03-23-2014, 20:18 | #454 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | Once again if the he is using an iphone with the original carrier sprint or Verizon then the 64k will not give him the 3g unless if he jailbreak his iphone and install the neterteam patch, the 64k it's good for 3g without jailbreak only for the att iphone. |
03-28-2014, 07:43 | #455 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2156560 Status: Offline Thanks Meter: 0 | Hello, I am new to this and I do apologize if I posted in the wrong area. I have a sprint iphone 5 iOS 7.1. I got a gpp sim online. And was able to get pass the activate screen with it and activate simple mobile but I can only make phone calls. I can't send texts only receive them. I can't use data either. I did the sim swap method to edit the apn settings and set the apn settings from simple mobile. Still no luck. I also tried using the irose method. And no luck. I can still only make phone calls and receive texts but I can't reply or use data. Can someone help? Thanks in advance! |
03-28-2014, 07:43 | #456 (permalink) |
03-28-2014, 18:57 | #457 (permalink) |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | What is the packaging of your GPP? Some GPP do not support iOS 7 3G mode. Try this patch in Safari: unlockpro.ru/nano4g, install, and click Force 2G. Can you send MEID of Sprint iPhone 4S? I will check to make sure it's clean ESN. Does Settings, Phone, My Number show old Sprint phone number or Unknown? |
03-28-2014, 18:57 | #458 (permalink) |
03-29-2014, 02:51 | #462 (permalink) |
Member: 2150837 Status: Offline Thanks Meter: 0 | i use ios 5.1.1 jailbreaked, when i put the rsim air, that activation required pop up show, and i cant continue, some time i can choose the operation selection and complete the step, but after restart, thats back again ini activation pop up |
