07-18-2014, 10:19 | #1 (permalink) |
Junior Member Join Date: Jul 2008
Member: 814915 Status: Offline Thanks Meter: 0 | R-SIM AIR, iPhone 4S, no 3G... Please help! I've checked its authenticity and it went ok. I've replaced my original SIM for this one along with the provider's SIM I want to use and it worked fine. But I only got Edge network. I thought it could be related with LTE patch so I purchased an activation code and I was able to apply the code successfully. But still no 3G... Not even the option under settings>cellular. So I upgraded to 7.1.2 (was 7.0.1) and still no 3G... Now, I also have a new message, I had never seen before when I try to setup the hotspot ("To enable personal hotspot on this account, contact Vodafone P") I did install a specific profile for APN for this operator, I obtained it from unlockit. co. nz Original network: Vodafone Portugal Current network: Tesco Mobile (they are a MVNO) Can this be related to the fact that I don't have my phone jailbroken? Please advise, Thanks, LM Last edited by lmartinho; 07-18-2014 at 10:21. Reason: Trying to add attachement photos |
07-18-2014, 13:10 | #2 (permalink) |
Major Poster Join Date: Jul 2014
Member: 2219195 Status: Offline Thanks Meter: 11 | Hi friend,i'm steve from RSIM team. If you want to solve iphone4s 3G problem,you need rsim air and jailbreak,then add the:www.isamteam.com rsim repo and istall the C&D patch. |
The Following User Says Thank You to Steve-J For This Useful Post: |
07-19-2014, 09:29 | #3 (permalink) | |
Freak Poster Join Date: Dec 2007
Member: 643752 Status: Offline Thanks Meter: 10 | Quote:
07-28-2014, 12:16 | #4 (permalink) |
Member: 814915 Status: Offline Thanks Meter: 0 | Hello Steve, thanks for the suggestion. I've did your recommendation, but the patch didn't do the work, or maybe I've installed the wrong patch? I've installed A1:CommCenter patch and C:R-SIM iOS 7/6 4S Please advise if I should remove those and install another. 3G is still not working... Thank you! |
07-28-2014, 14:57 | #5 (permalink) |
Member: 814915 Status: Offline Thanks Meter: 0 | IT Finally worked!!! I'm posting the steps, as someone else may need it! All I needed was to change the R-sim mode to "Mode 2 (iOS6) M2 3G" The title of the option was misleading, as it worked and I'm running 7.1.2 (I don't know, though, if the isamteam patch from Cydia is needed or not, as I had it already installed from previous attempts) Thank you, and keep up the good work, this forum rocks! |
07-30-2014, 09:53 | #6 (permalink) | |
