Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 03-11-2020, 22:38   #16 (permalink)
Member: 2213455
Thanks Meter: 17
Tanq. Good update. Tested on iphone se with t mobile and 7 pluse att lock
But 2 questions
1 update 19.3 or 16.2 ??
Im chk support cant find 19.3. Only 16.1 and 16.2 new
2. I have tracfone lock. On r sim no tracfone and update rsim to 16.2 must select operator and select iccid unlock with 16.2 no tracfone and only iccid mode activation
Old 03-11-2020, 23:39   #17 (permalink)
Member: 2274427
Thanks Meter: 23
working iphone 6s X Xs max 8 plus (sprint) 11 pro max (sprint)
Old 03-12-2020, 00:08   #18 (permalink)
Member: 2489241
Originally Posted by carlos_07 View Post
does not work with r-sim 13
Nope, those aren’t working since you must keep the RSIM card in the tray in order to work. I know for sure bc that was the first thing I’ve tried
Old 03-12-2020, 00:11   #19 (permalink)
Member: 43098
Thanks Meter: 71
Does this new method work with rSim 15? The dual card version in the pink plastic case?
I can verify it works with rSim 14 for the XR series in the green plastic case.
Old 03-12-2020, 01:07   #20 (permalink)
Member: 2830525
Thanks Meter: 5
Oke
Sent from my CPH1701 using Tapatalk
Old 03-12-2020, 02:34   #21 (permalink)
Member: 2213455
Thanks Meter: 17
And don't forget that rsim cant relase update for user
With new ios apple like before open iccid active
You can active with any unlocker sim with any version .
Good luck
Old 03-12-2020, 04:53   #22 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 2,693
V19.1 and v19.2 is working too , the net worker will upload the v19.3 today ,
The Following User Says Thank You to kinglock For This Useful Post:
Old 03-12-2020, 05:24   #23 (permalink)
Member: 824955
Thanks Meter: 2
Osea ustedes no tenían preparada la actualización para Dongle de rsim 15 y esto fue un golpe de suerte que les ha traído de vuelta al negocio ? Nos edtaban mintiendo al hacer esperar por algo que no había y ahora con suerte bum regresaron , pero hasta cuándo será esto ?
Old 03-12-2020, 06:41   #24 (permalink)
Member: 1907775
Thanks Meter: 2,693
http://www.rsim5.com/intro.php?id=14
Old 03-12-2020, 11:50   #25 (permalink)
Member: 2709727
Iphone 6 12.4.5
what about iphone 6 ios 12.4.5
not working
any solution ?????????
Old 03-12-2020, 17:25   #26 (permalink)
Member: 670004
Thanks Meter: 7
yes, jailbreakit and modified some files on the os, and iccid gonna work , google it
The Following User Says Thank You to EL_SaNdUnGuErO For This Useful Post:
Old 03-12-2020, 17:34   #27 (permalink)
iamtj's Avatar
Member: 2048052
Thanks Meter: 18
Originally Posted by kader1303 View Post
I have RSIM 14 but doesn´t show pop up menu when inserted mabe are old version software, thats why im asking if need to update and what dongle to use for this RSIM
update fw to 14.9
Sent from my iPhone using Tapatalk
Old 03-13-2020, 14:03   #28 (permalink)
Member: 2683247
Thanks Meter: 19
not working
To make it work, you need to jailbreak your device and follow this method.
For users below the iPhone 6S (i5 / 5C / 5S / 6 / 6Plus) who want to use the ICCID unlock method, they need to jailbreak their iPhone. From Cydia, install Filza File Manager.
Open Filza, then go to System / Library / Coreservices. There you will find the SystemVersion.plist file. Open this file and you will find ProductBuildVersion. We need to change the value of this ProductBuildVersion to 17D50. Then come back, you will find ProductVersion, and we need to change the value to 13.3.1 and save.
Now hard reset your iPhone. Your device will show software version 13.3.1 (17D50)
Now you can unlock your device using the ICCID unlock method
After activation by ICCID, return the version and number of your firmware via jailbreak.
The Following User Says Thank You to Tolbas For This Useful Post:
Old 03-14-2020, 16:51   #29 (permalink)
Member: 2459251
Thanks Meter: 56
https://firmwarex.net/new-iccid-update/
Old 03-14-2020, 18:16   #30 (permalink)
Member: 2683247
Thanks Meter: 19
Activation by ICCID iPhone 6, 6+ and 5s:
1.We take the phone, put the jail checkrain 0.9.8.2.
2. We go into the side and put Filza File Manager and Apple File Conduit “2”
3. Through Filza we go along the path System / Libraries / Coreservices. Copy the SystemVersion.plist file to the same folder. The file will be called SystemVersion (1) .plist
4. Open SystemVersion.plist, find ProductBuildVersion. Change the value of ProductBuildVersion to 17D50. Then we return and in ProductVersion we change the value to 13.3.1. Click save and done.
5. We reboot the device with the buttons. The download will be long, with a running status bar.
6. After loading the device, insert the sandwich and enter the current ICCID in the drop-down menu.
7. We go through the activation and we have a fully functioning device. (will not work without a gasket)
Now return the firmware version:
1. We take the phone, again we put the jail checkrain 0.9.8.2.
2. Thanks to the Apple File Conduit “2” tweak installed earlier, we connect the phone to any program (iTools, 3Utools, etc.) and go to the “File System” section.
3. In 3Utools, as an example, we go along the path System / Libraries / Coreservices. Delete the SystemVersion.plist file and rename the previously copied source file named SystemVersion (1) .plist to SystemVersion.plist. That is, without "(1)".
4. We reboot the device with the buttons. The download will be long, with a running status bar.
That's all. The phone remains on the old firmware 12.4.x and works as a non-wizard. After all the manipulations, all applications work stably, both old and just installed.
The Following 2 Users Say Thank You to Tolbas For This Useful Post:
Page generated in 0.25789 seconds with 9 queries
