Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & SAM SIM
Old 03-14-2020, 18:16   #31 (permalink)
Member: 2683247
Thanks Meter: 18
Activation by ICCID iPhone 6, 6+ and 5s:
1.We take the phone, put the jail checkrain 0.9.8.2.
2. We go into the side and put Filza File Manager and Apple File Conduit “2”
3. Through Filza we go along the path System / Libraries / Coreservices. Copy the SystemVersion.plist file to the same folder. The file will be called SystemVersion (1) .plist
4. Open SystemVersion.plist, find ProductBuildVersion. Change the value of ProductBuildVersion to 17D50. Then we return and in ProductVersion we change the value to 13.3.1. Click save and done.
5. We reboot the device with the buttons. The download will be long, with a running status bar.
6. After loading the device, insert the sandwich and enter the current ICCID in the drop-down menu.
7. We go through the activation and we have a fully functioning device. (will not work without a gasket)
Now return the firmware version:
1. We take the phone, again we put the jail checkrain 0.9.8.2.
2. Thanks to the Apple File Conduit “2” tweak installed earlier, we connect the phone to any program (iTools, 3Utools, etc.) and go to the “File System” section.
3. In 3Utools, as an example, we go along the path System / Libraries / Coreservices. Delete the SystemVersion.plist file and rename the previously copied source file named SystemVersion (1) .plist to SystemVersion.plist. That is, without "(1)".
4. We reboot the device with the buttons. The download will be long, with a running status bar.
That's all. The phone remains on the old firmware 12.4.x and works as a non-wizard. After all the manipulations, all applications work stably, both old and just installed.
The Following User Says Thank You to Tolbas For This Useful Post:
Old 03-14-2020, 22:29   #32 (permalink)
Member: 2937138
Thanks Meter: 2
Originally Posted by Pham Hung DN View Post
Ok - ICCID : 89014103270421600735​ - works with this R-SIM ????
Old 03-15-2020, 17:25   #33 (permalink)
BoOzer665's Avatar
Member: 44186
Sonork: 100.108965
Thanks Meter: 65
89014103270421600735 not working today .. anyone can confirm?
Old 03-15-2020, 17:47   #34 (permalink)
BoOzer665's Avatar
Member: 44186
Sonork: 100.108965
Thanks Meter: 65
89014103270421600735 works 100% .. device must be 13.3.1 .. sorry all
Old 03-15-2020, 20:26   #35 (permalink)
Member: 2936730
Thanks Meter: 2
Works Rsim RSIM 15 pro v19.1 only !
Old 03-15-2020, 21:07   #36 (permalink)
Member: 219402
Thanks Meter: 10
works with all kind of proxy sims you buy this or last year.
Old 03-16-2020, 04:53   #37 (permalink)
Yong Vannak's Avatar
Member: 770210
Thanks Meter: 46
wow work good %100 iPhone 11 Pro Max ios13.3.1 lock AT&T I use RSIM15+ ICCID: 89014103270421600735 with sim Verizon USA
thank you so much
03/15/2020
Old 03-16-2020, 11:17   #38 (permalink)
Member: 237628
Sonork: 100.1668254
Thanks Meter: 136
I phone 6
is that possible iphone 6 g-vey?
Old 03-17-2020, 08:08   #39 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,719
Originally Posted by carlos_07 View Post
does not work with r-sim 13
update your rsim card to v19.3 tested 100% work
Old 03-18-2020, 08:14   #40 (permalink)
rj.any1's Avatar
Member: 2071246
Sonork: 100.1652455
Thanks Meter: 80
can u give us any video link ?
Old 03-19-2020, 21:05   #41 (permalink)
Member: 2082183
Sonork: 100.1638535
Thanks Meter: 47
all old and new sim working by iccid mode
Old 03-20-2020, 07:15   #42 (permalink)
Member: 649584
Thanks Meter: 11
Originally Posted by Knowledge View Post
Does this new method work with rSim 15? The dual card version in the pink plastic case?
I can verify it works with rSim 14 for the XR series in the green plastic case.
yes i can confirm the rsim 15 works on
iphone 8 plus at&t
iphone xr at&t
iphone x sprint
Old 03-20-2020, 15:15   #43 (permalink)
Member: 1036725
Thanks Meter: 31
With r-sim13 something unlock now work?
Old 03-20-2020, 18:11   #44 (permalink)
Member: 2903295
R-sim 12 working fully tested with iphone 7
Sent from my LG-M703 using Tapatalk
Old 03-20-2020, 22:46   #45 (permalink)
Member: 2120988
Thanks Meter: 13
can i buy on ebay ? please give me link.
thanks advanced
Page generated in 0.18520 seconds with 7 queries
