Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 09-12-2018, 04:21   #1 (permalink)
Member: 2863492
Thanks Meter: 4
RSIM 12 "Activation Required" more than once a day
Hi guys. I have an Iphone 7 unlocked of T-Mobile. I use in Argentina with Movistar. The thing is, every day, I got the messege "Activation required", randomly, once o twice a day. I apply the config and it's ok. But it's annoying to do that every day. What can I do?
Old 09-13-2018, 21:06   #2 (permalink)
Member: 2783707
Thanks Meter: 189
Remove the RSim and insert only your own sim
The Following 2 Users Say Thank You to parrotgeek1 For This Useful Post:
Old 09-13-2018, 22:26   #3 (permalink)
Member: 2863492
Thanks Meter: 4
Thanks for the reply. I tried that. But when I do that, the message keeps coming 🤷🏻*♂️
Enviado desde mi iPhone utilizando Tapatalk
Old 09-14-2018, 01:30   #4 (permalink)
Member: 2783707
Thanks Meter: 189
When you remove the RSim Does it pop up always Or do you have signal some times and other times it shows activation required? If it always shows activation required then the RSim is in tmsi mode and not supreme sharp mode. Change the mode and insert the newest iccid
The Following User Says Thank You to parrotgeek1 For This Useful Post:
Old 09-14-2018, 01:49   #5 (permalink)
Member: 2863492
Thanks Meter: 4
Yes, I use tmsi automode1. It’s the only config it worked for me. I’m gonna try your method. Any iccid working? Pm me!
Old 09-14-2018, 03:12   #6 (permalink)
Member: 2863492
Thanks Meter: 4
Well, I tried your tips, and it worked. I used an iccid from the forum and it's working. I'll see if in the next days the messege of "activation required", comes again. Thanks!!!
Old 09-14-2018, 06:12   #7 (permalink)
Member: 2783707
Thanks Meter: 189
To 100% make sure if it works, check if the Carrier field on About in settings matches the REAL carrier instead of the carrier the phone is locked to. (Except, if you are using a carrier which is not an Apple supported carrier it will just say "Carrier" as the carrier)
Like this picture (actual picture of my own locked iPhone SE with GPP SIM which is an RSim competitor but they all work the same)
Old 09-15-2018, 06:10   #8 (permalink)
Member: 2863492
Thanks Meter: 4
I have “carrier 32.0”. I’m using Movistar from Argentina. It’s ok?
Old 09-15-2018, 17:19   #9 (permalink)
Member: 2783707
Thanks Meter: 189
Yes because only Claro is officially supported https://support.apple.com/en-us/HT204041
In this case the actual way to check (I promise this one will work) is to download this app System Information Lite by PearApps https://itunes.apple.com/us/app/syst...351270874?mt=8
Open the app and look where it says MCC/MNC and country code. The MCC/Mnc should be 722 and 070 (or 70) and the country code should of course be ar. If MCC is 722 and MNC is something else it's probably good too and I have wrong information about movistar.
In the case that the MCC and MNC match, this is good and means that the iPhone "knows" about the real carrier and is not being tricked by the TMSI exploit, and so the activation required will never pop up.
I really need to write a post with all of this information combined about the different unlocking modes and how to check if they are working.
Old 09-15-2018, 19:40   #10 (permalink)
Member: 2863492
Thanks Meter: 4
Network:
Wifi IP Address: hidden
Cell IP Address: hidden
Subnet Mask: 255.255.255.0
BSSID: e0:41:36:6b:ed:f0
SSID: Speedy-6BEDF0
Carrier: Carrier
Country Code: ar
MCC / MNC: 722 / 07
Allows VOIP: YES
External IP: hidden
This is what the app says. The hidden numbers, are for obvious reasons
The Following User Says Thank You to jimmynukem For This Useful Post:
Old 09-15-2018, 19:44   #11 (permalink)
Member: 2783707
Thanks Meter: 189
Carrier: Carrier
Country Code: ar
MCC / MNC: 722 / 07
This is correct. Your iPhone has been perfectly unlocked with the ICCID and it will never show activation required. You can even remove the R-SIM and insert only your SIM now! (until you factory reset the phone)
Old 09-15-2018, 19:45   #12 (permalink)
Member: 2863492
Thanks Meter: 4
Many many thanks man! You’re my hero!
Old 09-15-2018, 20:43   #13 (permalink)
Member: 2863492
Thanks Meter: 4
One last question. Can I turn off/restart my Iphone normally right? No “activation required” message?
Old 09-15-2018, 20:45   #14 (permalink)
Member: 2783707
Thanks Meter: 189
Yes. You only have to enter a new iccid when you factory reset (settings -> general -> reset -> erase all content and settings, or itunes restore)
Old 09-15-2018, 23:21   #15 (permalink)
Member: 2863492
Thanks Meter: 4
Thanks a lot. If I have any other question, I’ll contact you
Page generated in 0.22705 seconds with 9 queries
