05-29-2019, 15:27 | #1 (permalink) |
Junior Member Join Date: Feb 2006
Member: 231400 Status: Offline Thanks Meter: 0 | R-SIM12 help iPhone XR iOS 12.2 I use the pop up menu, and edit the ICCID, then put the latest code from the website and it says activation error. “Activation request could not be completed. Please try again. If the problem persists, please contact customer support. “ |
05-29-2019, 17:56 | #2 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2805408 Status: Offline Thanks Meter: 5 | update the software to 12.3 than try again. it should go through just fine. if you get same error. put the original simcard for the carrier (not the one you want to use) along with chip. and edit iccid ( setting - cellular - simapplication ) than change the simcard to the one you like to use it with.. will work just fine! |
The Following User Says Thank You to rajx05 For This Useful Post: |
