Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & SAM SIM
Old 09-18-2018, 18:58   #16 (permalink)
Member: 2863492
Thanks Meter: 3
Originally Posted by parrotgeek1 View Post
Yes. You only have to enter a new iccid when you factory reset (settings -> general -> reset -> erase all content and settings, or itunes restore)
Hey, bro, here I’m again. Do you know if the rsim will be compatible with iOS 12? Should I upgrade, or wait?
Enviado desde mi iPhone utilizando Tapatalk
Old 09-18-2018, 22:32   #17 (permalink)
Member: 2783707
Thanks Meter: 170
Upgrade, it works (if you look at my screenshot I posted earlier it says 12.0 under Version)
The Following User Says Thank You to parrotgeek1 For This Useful Post:
Old 10-02-2018, 02:36   #18 (permalink)
Member: 2265024
Thanks Meter: 11
i have a two phones on IOS 12.0 after a while, it keeps showing invalid sim or sim failure. I have checked the app on one of them and they mcc & mnc are different.
anybody have the same problem or a solution ?
Old 10-02-2018, 03:41   #19 (permalink)
Member: 2783707
Thanks Meter: 170
Make sure you pressed 3G 4G supreme sharp mode
After you input the newest iccid just remove the RSim and insert your sim only and all issues are fixed
Old 10-02-2018, 15:40   #20 (permalink)
Member: 2863492
Thanks Meter: 3
Hi. Is it a condition having the roaming on?
Old 10-02-2018, 18:56   #21 (permalink)
Member: 2783707
Thanks Meter: 170
No. It can be off. The only reason it needed to be on before was that the phone thought the "home" carrier was T-Mobile.
Old 10-02-2018, 19:02   #22 (permalink)
Member: 2863492
Thanks Meter: 3
So, once the phone is succesfully unblocked, there’s no need to keep the roaming on? My phone was blocked with t-mobile
Old 10-02-2018, 21:26   #23 (permalink)
Member: 2783707
Thanks Meter: 170
Correct.
P.S. It's "unlocked"
Old 10-02-2018, 21:33   #24 (permalink)
Member: 2863492
Thanks Meter: 3
Correct.
Right! English is not my primary language. Sometimes I have a mistake. One last thing. Is it possible to enable the option “personal hotspot”? Because when I try to set it up, I got the message “to enable personal hotspot on this account, contact Carrier”. In my case, “carrier” is movistar from Argentina
Old 10-02-2018, 21:47   #25 (permalink)
Member: 2863492
Thanks Meter: 3
I quote myself. Solved the “personal hotspot” thing. Just needed a config. Nothing to do with the Rsim
Old 10-09-2018, 02:17   #26 (permalink)
Member: 474604
Thanks Meter: 5
is the latest iccid ending in 7803 working? when i use it the phone looks like its about to activate but a white screen shows up with a itunes logo in the center of screen when i try again it shows invalid sim top left corner of screen then it activates to home screen showing same invalid sim top left corner where carrier and signal should be
iphone 7 on ios 12
using rsim12
Old 10-09-2018, 03:15   #27 (permalink)
Member: 2863492
Thanks Meter: 3
iphone 7 on ios 12
using rsim12
I guess that iccid is not working. Try with another. But first, select 3g/4g supreme sharp, restart the iPhone, and then, edit the iccid, and restart again. The curious thing is that when I entered the iccid, the iPhone started like if it was lost. Since then, never again ‘activation required’
Old 01-10-2019, 20:10   #28 (permalink)
Member: 2863492
Thanks Meter: 3
Hi again. I’m having trouble with the sms. Every time I have to send one, I have to configure the SMSC. Anything I can do?
Old 01-11-2019, 18:20   #29 (permalink)
Member: 2783707
Thanks Meter: 170
Remove the RSim and insert only your own sim then configure the SMSC and put back the RSim (if you want; you don't actually need to put it back)
Old 01-12-2019, 05:30   #30 (permalink)
Member: 2863492
Thanks Meter: 3
Thanks for the reply. I’ll do it!
Page generated in 0.38894 seconds with 7 queries
