11-08-2013, 13:58 | #1 (permalink) |
Insane Poster Join Date: Nov 2013
Member: 2061108 Status: Offline Thanks Meter: 0 | Rsim 8 on iphone 5 issue i got it to work i activated my iphone 5 with rsim8 put it to iphone 5 mode with att us carrier than i replaced the carrier to my sim (israel) with 7 digit and reset iphone now its only ''searching'' why?/ edit- now it says "Activation Required" what do i need to do? when i check which carrier im in it shows me my carrier... so why it asking me to activate? ://// Last edited by alioop1; 11-08-2013 at 14:06. |
11-08-2013, 22:20 | #2 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Philippines
Member: 17609 Status: Offline Sonork: 100.64817 Thanks Meter: 1,694 | Quote:
Follow this instructions 1.Insert the sim and ur rsim 2.select iphone model 3.select carrier so its ATT right? 4.then Accept it 5.Reboot once If its activation right now use other sim then follow the instruction, then repeat again insert your simcard you want to use then repeat the procedure. Br, Ron2pet | |
11-09-2013, 01:09 | #8 (permalink) | |
7 digit imsi its ok and your iphone not requiring activation so your imsi is ok try this USA ATT 3104103 also if you have other simcard from your country pls try it BR | |
