Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 07-30-2014, 12:10   #1 (permalink)
Member: 2230930
Exclamation rsim mini2 9.5 problem with travell
T-Mobile iPHONE 5S 7.1.1 - USING RSIM MINI2 V9.5
I'm getting 100% stability on 3G. I'm getting 4-5 bars (Mostly 5) when on 3G; 5 continuos bars when on 2G. Incoming calls & SMS works too. (But all those functions works perfect when moving aroung a Home).
The only problem I faced today is when I was travelling upto 25 km; the phone jumps into Activation mode while on even 2G. Is there any resolution for that?? I was using Idea sim card that time. When I reached to my hometown; not a single process worked to fix activation loops. I was facing conitnuos activation loops that time, no matter which career sim card I'm using. I have to reset it to factory settings via iTunes.
I'm worried if it again happens with Vodafone SIM Card, then I have to reset every time which is very disappointing.
I hope someone will have fix to this problem.
Old 07-30-2014, 22:02   #2 (permalink)
Member: 2230930
rsim mini 2
plz any one help me plzzzzzzzzzzzzzzzzzz
Old 07-31-2014, 10:18   #3 (permalink)
Member: 2156531
Thanks Meter: 10
All are having same problem with 9.5
Old 07-31-2014, 10:18   #4 (permalink)
Member: 2156531
Thanks Meter: 10
It goes on activation while travel
Old 07-31-2014, 10:19   #5 (permalink)
Member: 2156531
Thanks Meter: 10
You select manual network search mode
Old 07-31-2014, 10:21   #6 (permalink)
Member: 2156531
Thanks Meter: 10
After that you select vodaphone in. Whenever you go in no service area it will prompt for ''no service''. Just discard the message. When you come in service zone, vodaphone in automatically appear.
Old 07-31-2014, 10:22   #7 (permalink)
Member: 2156531
Thanks Meter: 10
May this one will be helpful for you otherwise u update ur mini to latest virsion
Old 07-31-2014, 11:15   #8 (permalink)
Member: 2180962
Thanks Meter: 21
Try to update to the latest version, V10.1
Old 07-31-2014, 18:26   #9 (permalink)
Member: 2230930
thanks i will try this issu
Old 08-01-2014, 04:16   #10 (permalink)
miliky's Avatar
Member: 38751
Sonork: 100.75985
Thanks Meter: 2,573
RSIM 9 PRO mini air,R-SIM8+,SAMSIM,3G,R-SIM5+,R-SIM6,RSIM5+,RSIM6,RSIM7,R-SIM7+?Unlock,iPhone5,iPhone4S,Firmware,Any version, No jailbreak please update to the newest 10.1 program!
Old 08-01-2014, 05:32   #11 (permalink)
Member: 2156531
Thanks Meter: 10
best solution for current version is first you keep manual searching mode and while traveling u just on airplane mode. when u reach to the destination off the airplane mode
Old 08-01-2014, 05:33   #12 (permalink)
Member: 2156531
Thanks Meter: 10
or you upgrade ur card as others told
Old 08-01-2014, 08:56   #13 (permalink)
Member: 2230930
I hope so, but I do not have dongle updater in Egypt
Here I bought a activation code only
Old 08-01-2014, 13:53   #14 (permalink)
Member: 2230930
I try Buy Now
But is there to confirm that he will solve the problem
Old 08-05-2014, 13:18   #15 (permalink)
Member: 2203129
I try Buy Now
Yes, the jump activation screen should no longer appear after updating to 10.1.
Page generated in 0.22110 seconds with 9 queries
