Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & SAM SIM
Old 11-20-2017, 16:13   #1 (permalink)
Member: 1907775
Sonork: 1653265:unlocker
Thanks Meter: 2,056
RSIM12 V9.1 Use instruction
How setting V9.1 RSIM12 to new Auto 4G
https://www.youtube.com/watch?v=6dqX...ture=*********
The best to all rsim user. all the new verizon RSIM12 no need setting , plug and play . Welcome order from our reseller .
How to use R-SIM12 TMSI Model--From 6th Dec 2017
https://www.youtube.com/watch?v=F0R-URnMu9Q
1、The default version,au /sb/sprint/docomo/att/vrzen,etc,inserting it and 4G signal availble automatically, namely 4G auto mode ( Fit for 5s to iphone x ), similar to unlocked Non-contract iphone.
If the default iccid mode when changed or upgraded are not in accordance, (such as updating ios11 or ICCID changed, always pop out informing menu to activate ): after inserting mobile card and SIM card, no matter what state of your mobile ( including the mobile signal and 4G already available) , dial following command *5005*7672*00# and reelect operator.
Edit ICCID, Input 20 DIGITAL ICCID CODE
New functions:
1. ICCID perfect unlock
2. 6s,6s9,se perfect unlock. Choosing corresponding operator and unlocking mode, take out the card and insert it in to wait signal. CMCC and Unicom unlocked perfectly.
PS:If no signal after waiting for about 1 min, after all setting done, taking out and insert card once again, then signal available soon.
3.TMSI unlock AUTOMODE1 mode, as TMSI mode not perfect unlocking, sometime signal will be off or no service, this mode can gain signal automatically.
Above operation pls refer to video instruction.
4.TMSI unlock AUTOMODE1 mode, is quicker for signal receiving than AUTOMODE1, and no need dialing 112 for quick signal receiving. ( This mode recommeded )
5.Sim card program support sim card reader update
SIM Card menu
一、 It is double mode unlock, fit for most mobile in 2g GSM net
二、TMSI Mode applied in 4G net, with 4 unlock modes.
Enter in menu, there’re 4 modes for choice.
2.1Manual MODE1(CMCC, Unicom UNLOCK)
Instruction: Enter into Activate mode, wait for 4g net appeared, then dial 112. Take out sim card and insert in, and wait for signal appeared.
Choosing this unlock mode, mobile will enter into activate mode automatically if signal off, and there will be sound notice to unlock again and regain signal, in case of missing call. ( Operation Instructions please refer to video. )
2.2 Manual MODE2(CMCC, Unicom UNLOCK)
1st step: Insert Sim card and mobile card into mobile, choose your mobile operator, choose Manual Mode2, then click Accept button, complete card setting, turned your mobile off and then turn on.
Step 2: enter into Sim card application program, choose
mobile will enter into “ Need activating mode” automatically, take care of mobile signal and 4G signal, wait for seconds and dial 112, in seconds, take off card and insert in quickly, then wait for signal and complete unlocking. ( If it doesnot work at first time, please try a few more times.
PS:This method fits for unlocking CMCC card.
2.TMSI unlock AUTOMODE1 mode, as TMSI mode not perfect unlocking, sometime signal will be off or no service, this mode can gain signal automatically.
2.TMSI unlock AUTOMODE1 mode, is quicker for signal receiving than AUTOMODE1, and no need dialing 112 for quick signal receiving. ( This mode recommeded )
2.4 CMCC can unlock by following methods:
Method 1
2.4.1Instruction step: choose“
”->Manual mode2, then take off card, and insert SIM card in mobile phone alone, 4G signal appears, click “ mobile data activate phone”, SIM card shows invalid, then turn off mobile phone to take off SIM card. Insert SIM Card together with mobile card into mobile phone, waiting for mobile gaining signal.
Method 2
2.4.2 1st step: Insert Sim card and mobile card into phone, choose“
”mode, click “Accept, complete card setting.
Step 2: take out SIM card, insert Unicom and CMCC 4g card into mobile phone, mobile recognized SIM card, it will enter into “ Activation required” automatically, mobile will appears solid 4G signal, click next step and it shows SIM card invalid, then turn off mobile. ( mobile screen turns black, and wait 10 seconds for fully off ).
Step 3: Insert Mobile card and SIM card into mobile, turn on mobile phone, CMCC signal will appear. Or sometimes 2G signal appears first, wait for a moment, then Unicom and CMCC 4g signal gained.
三、 4G CDMA sime supreme sharp; CDMA 4g ios 9 to ios11 unlock method
Step 1: Insert SIM card and telecom card into mobile phne, choose CDMA4G if you use telcom card, then choose relevant operator ( only sprint, Japan AU and softbank 3 version support telecom), then click “ Accept” , complete card setting.
Step 2: take out card, insert telecom card into mobile phone alone, mobile will recognize SIM card and enter into “ Activation required” mode automatically, then mobile will appear solid full signal and 3G, if you use 4G card, mobile will appear solid 4G signal, then click next step to activate. Mobile will show invalid SIM card, then turn off your mobile phone. ( mobile screen turns black, and wait 10 seconds for fully off ).
Step 3: Insert mobile card and SIM card together into mobile phone, turn on mobile phone, telecom signal will appear, complete unlock.
In SIM card application function
“Regain SIM signal” is applied to anti-activation, if under TMSI unlock mode, no signal appears, please click this to gain signal
TElecom 4G
CMCC 2G
CMCC 4G
RSIM12 V9.1 Use instruction RSIM 10+,RSIM9+,RSIM 9 PRO mini air,R-SIM8+,SAMSIM,3G,R-SIM5+,R-SIM6,RSIM5+,RSIM6,RSIM7,R-SIM7+?Unlock,iPhone5,iPhone4S,Firmware,Any version, No jailbreak
The Following 9 Users Say Thank You to kinglock For This Useful Post:
Old 11-20-2017, 18:35   #2 (permalink)
Member: 2540958
Thanks Meter: 65
what is the cust of this sim
The Following User Says Thank You to jesse k kondoba For This Useful Post:
Old 11-20-2017, 19:22   #3 (permalink)
Member: 2171849
Sonork: no
Thanks Meter: 95
its work with tracfone?
The Following User Says Thank You to aminbr25 For This Useful Post:
Old 11-20-2017, 20:30   #4 (permalink)
Member: 1668925
Does it work with Tracfone USA / Straighttalk??
The Following User Says Thank You to albertolpz94 For This Useful Post:
Old 11-21-2017, 04:00   #5 (permalink)
Mubashir999's Avatar
Member: 2570477
Thanks Meter: 425
This sim also Work on sprint Network?
Old 11-21-2017, 04:46   #6 (permalink)
MISHUK_SIKDER's Avatar
Member: 1245067
Sonork: 100.1612383
Thanks Meter: 18
its work with 5s tracfone...?
Old 11-21-2017, 10:59   #7 (permalink)
sunshine4u's Avatar
Member: 1383464
Sonork: 100.1669490
Thanks Meter: 97
No solution for tracfone
Old 11-21-2017, 11:42   #8 (permalink)
AsimGsmwork's Avatar
Member: 1752987
Thanks Meter: 17
Old 11-22-2017, 06:31   #9 (permalink)
Member: 772508
Thanks Meter: 13
works on sprint and tracfone ?_? rsim11 can be upgrade to this version ?¿
Old 12-03-2017, 04:28   #10 (permalink)
Member: 1751613
Thanks Meter: 75
how to removed icloud id bypass icloud id 100% work tool free downlod
http://www.youtube.com/watch?v=EwiXMSFMiZw
The Following User Says Thank You to riaz88833 For This Useful Post:
Old 12-03-2017, 21:39   #11 (permalink)
Member: 2722741
Thanks Meter: 2
Works perfect with sprint iPhone X with Tmobile service but once or twice a day my phone say sim not installed. I have to put the old sprint card in activate it then put rsim and Tmobile card back in and activate. Any solutions to solve this. When I do the *5005*7672*00# code nothing happens
Old 12-04-2017, 04:20   #12 (permalink)
Member: 1881607
Sonork: benjamyn
Thanks Meter: 87
Sorry bro it doesn’t work with tracfone phones
Sent from my iPhone using Tapatalk
Old 12-06-2017, 10:34   #13 (permalink)
Member: 417084
Thanks Meter: 23
apple stop all turbo
Old 12-06-2017, 13:12   #14 (permalink)
Member: 1907775
Thanks Meter: 2,056
Return to TMSI unlock mode.
Solutions for "SIM Not supported "
Old 12-07-2017, 04:13   #15 (permalink)
Member: 1907775
Thanks Meter: 2,056
https://www.youtube.com/watch?v=zCw_...2A%2A%2A%2A%2A
Page generated in 0.38743 seconds with 7 queries
