-   R-SIM & SAM SIM (http://forum.gsmhosting.com/vbb/f819/)
-   -   Solutions for "SIM Not supported " (http://forum.gsmhosting.com/vbb/f819/solutions-sim-not-supported-2272112/)
kinglock 10-05-2017 15:30
Please do as the video
RSIM12
https://www.youtube.com/watch?v=6dqXXFjxLlE
https://www.youtube.com/watch?v=F0R-URnMu9Q
video1:RSIM11+ Unlock For iOS11
https://www.youtube.com/watch?v=rW_a1Tb1YZI
video2:
https://www.youtube.com/watch?v=fHg095L240Q
video 3:
https://www.youtube.com/watch?v=J7mePcuAY2k
video 4:
https://www.youtube.com/watch?v=cFbL...ture=*********
The instructions for RSIM11+ return to unlock menu
https://lh3.googleusercontent.com/QE...Q=w517-h917-no
3th Home button Emergency Call
https://lh3.googleusercontent.com/Ij...w=w517-h917-no
4th Call *5005*7672*0#
https://lh3.googleusercontent.com/Nf...w=w517-h917-no
5th:
https://lh3.googleusercontent.com/sp...A=w517-h917-no
https://lh3.googleusercontent.com/rs...w=w517-h917-no
Settings SIM Applications
https://lh3.googleusercontent.com/bv...A=w516-h917-no
Lock Carrier
https://lh3.googleusercontent.com/k5...w=w516-h917-no
Return to TMSI unlock mode. Mobile Operation Flow Method①Ignore WiFi, open cellular data, data roaming, close 4G.
First adjust the card patch operator, insert the card + mobile card, input *5005 * 7672 * 11 # mobile phone will automatically find the mobile 2G signal, then open 4G on the OK method②good card paste. Close 4G, insert the card separately, and automatically jump to the upper-left corner of the activation screen to display 3G or E. Emergency dialing 112 to remain on and back out. Plug in the card and the phone card. Wait for 2G signal to appear, open 4G then. (Switch flight mode if a hollow signal appears during operation)
Methodology③
Switch on the card, insert the mobile card separately, and the phone automatically jumps to the WiFi activation interface. Five signal points and 4G appear in the upper left corner. Turn off the phone immediately (be sure to turn it off thoroughly). Then pull out the card and install the card and the mobile card. Turn it on and wait for the signal.
Method④There are many methods to move 4G, but I wont go through them here.
Unicom 4G operation method
Method①Put the card in place, insert the 4G card separately, appear 5 points plus 4G, emergency dialing 112, hold 112 for 5-8 seconds, switch to 5 points plus 3G, pull out the card directly, plug in the card sticker and the card, automatically send out the signal.
Telecom 4G Operation Method
Method①Adjust the card, dial the *5005*7672*11# code, and then prompt a message to restart the machine.
Methodology②
Switch on the card, plug in the card separately, and the phone automatically jumps to the WiFi activation interface. Five signal points and 4G appear in the upper left corner. Turn off the phone immediately (be sure to turn it off completely). Then pull out the card and install the card and the card. Turn it on and wait for the signal.
Operator Boot Directive *5005*7672*00#
Search signal instruction*5005*7672*11#
Carrier code:
http://www.rsim5.com/bottomlink.php?id=3
retaco82 10-05-2017 16:51
HEy
Can u clarify step by step? i have 300 rsims i had left over and need a solution
SIMTester 10-05-2017 17:15
It sounds like the solution will tie each phone to one SIM card, but at least there is some solution here. Now to figure out to use TMSI, Unicom, or Telecom solution.
gugbobgug 10-05-2017 17:44
any solution ? please make more clear post how to activate i am crazy here
if 4g not work no problem
2g so ok
Rocz.Mx 10-05-2017 18:53
Performing your proceed, an error pops-up where it says there's an error to change the address service center. 'No address'.
Keep waiting for a response.
nate.mills9911 10-05-2017 19:02
any solution yet , i have like 200 R sim please update or atleast post a video link
mynos 10-05-2017 22:39
not work this method or post Video whith directions! thanks in advance
accesoriosbelmo 10-05-2017 23:26
i hear a metoth for activacion with a mac like a VPN, anyone?
kinglock 10-06-2017 01:46
Return to unlock menu mode
active again . call *5005*7672*00# pop-up menu window on emergency call interface or *5005*7672*imsi(7 numbers)# and
then reset is okay. for example, *5005*7672*4405081# set to softbank carriehgvr .
Araltd 10-06-2017 02:20
Does this work with rSim 11+??
yesdomin 10-06-2017 03:24
How can i get the imsi ? i got phones for sell all of them with r-sim, i cant sell any one with this problem. HELP
Naymex17 10-06-2017 04:47
No se le entiende nada.
SIMTester 10-06-2017 07:48
Is this a solution for 2G or just to activate?
imbetow 10-06-2017 07:58
You need dial *5005*7672*00#
gugbobgug 10-06-2017 08:26
you have to choose gsm 2g option otherwise will not work
Page generated in 0.32497 seconds with 5 queries
