10-20-2017, 15:57 | #166 (permalink) | |
Junior Member Join Date: May 2017
Member: 2718431 Status: Offline Thanks Meter: 2 | Quote:
How you activate with rsim 11+? incoming calls works on screen lock? What sim you use? usim? | |
10-20-2017, 16:12 | #167 (permalink) |
No Life Poster Join Date: Mar 2014
Member: 2156606 Status: Offline Thanks Meter: 21 | I activated phone with Rsim 10+, and later I tried Rsim 11+, which I preprogrammed in other iPhone (carrier and working mode) and locked settings. But it must be iOS lower than 11.0.3. |
10-20-2017, 16:14 | #168 (permalink) | |
Freak Poster Join Date: Jul 2016
Member: 2596108 Status: Offline Thanks Meter: 58 | Quote:
Sent from my SM-G950F using Tapatalk | |
10-20-2017, 16:22 | #169 (permalink) | |
Member: 2156606 Status: Offline Thanks Meter: 21 | Quote:
I entered rsim 11+ into unlocked phone and enter imsi and gsm mode (2/3/4g) in sim application menu. After that I used it in iPhone 6 plus and it was working. But prior to that I have activated it with Rsim 10+ and tried with unprogrammed Rsim 11+ but it didnt worked. Can anyone try and let me know does it work ... Last edited by noctornus; 10-20-2017 at 16:24. Reason: update | |
10-20-2017, 16:23 | #170 (permalink) | |
I have I7+ T-mobile ios 10.3.3 Activated setings: i5-i7 usim mode1 unlock2 Works all but no incoming call when screen is lock. | |
10-20-2017, 16:43 | #171 (permalink) | |
10-20-2017, 17:18 | #174 (permalink) |
Member: 2156606 Status: Offline Thanks Meter: 21 | The point is to downgrade iOS to be prior to last one. If you're using Rsim 10+ it will give u Rsim menu when you try to activate it and it will work, if u re using Rsim 11+, u should put it into other unlocked phone and enter any settings (i used GSM Mode and also LTE 4g and lock or unlock settings) to make it run Rsim menu when you insert it into phone, because automatic mode cant activate it. I have tried before to bring rsim menu with those codes *5005* ... but couldnt get it. On unlocked phone I tried with tmobile imsi and GSM mode with locked settings and also as unlocked (rsim menu pops up on inserting into locked phone). Everything works as before. I am using iPhone 6Plus locked on Tmobile USA. |
10-21-2017, 19:07 | #176 (permalink) | |
10-23-2017, 02:47 | #177 (permalink) |
Insane Poster Join Date: Oct 2017
Member: 2767141 Status: Offline Thanks Meter: 18 | The point is if u want use r-sim 11+ code *5005*7672*0# pop up menu u must un tick/off lock carrier..use unlocked iphone to un tick/off lock carrier then u can use rsim 11+ into lock iphone... |
10-23-2017, 02:48 | #178 (permalink) | |
10-23-2017, 05:35 | #179 (permalink) | |
Member: 2767141 Status: Offline Thanks Meter: 18 | Quote:
Sory for my bad english😊 | |
10-23-2017, 07:37 | #180 (permalink) | |
Junior Member Join Date: Oct 2017
Member: 2770555 Status: Offline Thanks Meter: 0 | Quote:
Help please. Sent from my SM-N920C using Tapatalk | |
