Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & SAM SIM
Old 10-06-2017, 18:13   #31 (permalink)
Member: 2761262
Here's my guess about what he's trying to say:
1. When you see the activation screen, press 'home' to get the emergency dialer
2. Wait till you get the signal
3. Press *5005*7672*00# and dial - apparently it might take multiple attempts to get this one working
4. When it works you should get a popup. Enter the desired IMSI (scroll up for link to list of IMSI's)
5. Select TMSI unlock mode
6. Reboot as instructed
Old 10-06-2017, 19:02   #32 (permalink)
Member: 1208406
Thanks Meter: 8
Originally Posted by masoihuuan View Post
Anyone success bypass activation screen by Sim11+ yet ? Still can't able to pass through. Tried bypass Activation screen by using original sim; then put back the R-Sim & diffrent carrier; its said "Sim not Support" need help.
Hi gugbobgug I'm confuse I have a 6s Plus from at&T but i want to use the 6s Plus with tmobile network so dial *5005*7672*11# I need to use this code in the activation screen using emergency call windows right with rsim11+ original carrier sim card (at&T) into the iphone? then power off the iphone and change the sim card for Tmobile sim?
thank you for you help
Old 10-06-2017, 19:18   #33 (permalink)
Member: 2357447
each carrier need exactly msi code
foe example att need 3104101
t mobile need 3102620
Old 10-06-2017, 19:29   #34 (permalink)
Member: 2765226
Thanks Meter: 2
Anyone with xfinity insi code?
Old 10-06-2017, 19:30   #35 (permalink)
Member: 1950091
tried it ! It's said "Setting Failed, Service Center Address, No Address. any new method ? still have over 100 R-SIM 11+. All of them is failed.
Old 10-06-2017, 23:11   #36 (permalink)
Member: 2469862
Thanks Meter: 3
Can any one post video link for the process??
Old 10-07-2017, 00:09   #37 (permalink)
Member: 1208406
Thanks Meter: 8
OK for example I have an at&t iPhone 6s plus and I want to use with tmobile sim card. Well with r-sim11+ T-Mobile sim card into the iPhone at the emargency window dial *5005*7672*3104101# reboot the iPhone and that is it?????
Old 10-07-2017, 01:05   #38 (permalink)
Member: 2765071
Can someone please kindly make a video demo?
I appreciate any kind of help. Thank You.
Old 10-07-2017, 01:06   #39 (permalink)
Member: 1171722
Thanks Meter: 3
works for me ... only one minute signal ... make one call , after that... no service...
iphone 6 att 10.3.3 simcard telcel mx
Old 10-07-2017, 01:12   #40 (permalink)
Member: 2575858
Thanks Meter: 18
Hey Brother that's good news if at least you made it past the activation screen where it says SIM card not supported you can try more methods troubleshoot for us since you are the only one that was able to confirm this I am waiting for iPhone so I can test and troubleshoot
Sent from my SM-G955U using Tapatalk
Old 10-07-2017, 01:33   #41 (permalink)
Member: 2215160
Sonork: tyking5
Thanks Meter: 10
Mine says succeeded but service center address no address
Old 10-07-2017, 01:52   #42 (permalink)
Member: 2575858
Thanks Meter: 18
I'm having success bypassing the activation screen but I get stuck with no service or searching
Old 10-07-2017, 02:24   #43 (permalink)
Member: 1208406
Thanks Meter: 8
I have the same result after pass the activation screen "No service"
Old 10-07-2017, 02:25   #44 (permalink)
Member: 2575858
Thanks Meter: 18
I am able to finally set up 3G and 4G service but I still get stuck at SIM card not supported I make it to the home screen but it says no service or searching
Old 10-07-2017, 02:27   #45 (permalink)
Member: 2575858
Thanks Meter: 18
Is there a way we can confirm that Apple completely blocked us and this method and rsim11+ is not working so that way we don't waste time with the work around and troubleshooting!
Page generated in 0.39420 seconds with 7 queries
