11-02-2019, 10:27 | #1 (permalink) |
Product Manager Join Date: Mar 2013 Location: CH
Member: 1907775 Status: Offline Sonork: 1653265:unlocker Thanks Meter: 2,693 | Instruction For R-SIM15 Video: https://www.youtube.com/watch?v=nZ3n...ture=********* Insert SIM Card and R-SIM15 ( wait around 30s), choose relative carrier or press ‘IccidActivation’, input relative ICCID Code, (ICCID should be valid activating code), then choose relative unlocking mode ( usually choose “TMSI MANUAL”) Choose “Iccid Activation” Choose unlocking mode ICCID Setting Type 1: apply ICCID code activate unlocking operation instruction TMSI AUTO Use TMSI auto unlocking Mode ( Suggest this auto unlocking mode) Insert unlocking card, pop out menu Choose“IccidActivationChoose ”TMSI MANUAL” Pop out “Input ICCID Menu”( No need to revise ICCID, use default code ) Press Send Pop out “Setup OK”menu, press “Accept”, enter into activate mode Press Activate Wait for activating after activated then choose TMSI AUTO Mobile will Search signal automatically, following page will appear. Enter into unlocking mode, then wait for signal to appear. ( It may flashback Shortly when enter into activating mode during this period, as following pic) Signal appeared at upper Left Corner appeared Last edited by kinglock; 11-02-2019 at 11:00. |
11-02-2019, 10:27 | #2 (permalink) |
Member: 1907775 Status: Offline Sonork: 1653265:unlocker Thanks Meter: 2,693 | Wait it back to home page Wait signal to appear (PS: Under this unlocking mode, if appeared “ No Service”, enter into SIM card Application menu and press “Regain SIM Signal” to acquire signal.) 2:TMSI MANUAL MODE ICCID TMSI MANUAL UNLOCKING MODE Detailed operation steps please refer to manual unlocking mode video Then enter into “SIM card Application”, press“Regain SIM Signal” Wait for signal and “3G” symbol appeared, then dial “112” immediately, as following pic: Dialing 112, do not hang up, pull the card and then insert , waiting for the signa Type 2 Unlocking Mode: Choose Carrier unlocking instruction ( If ICCID blocked, apply following carrier unlocking way instructions) |
11-02-2019, 10:27 | #3 (permalink) |
Member: 1907775 Status: Offline Sonork: 1653265:unlocker Thanks Meter: 2,693 | TMSI AUTO Apply to choose carrier TMSI auto unlocking mode (Detailed operations please refer to auto unlocking mode video instruction) Insert card, pop out menu,choose carrierChoose TMSI AUTOPop out “input ICCID “ Menu ( No need to revise ICCID, Use default data) Press” send” Enter into unlocking mode automatically to unlock, if activate page appeared, it shows chose wrong carrier, have to choose a correct carrier again Enter into Unlocking Mode, wait for signal to appear. ( Auto flashback will appear shortly when entered into activate mode during this process, as following pic ) Upper left corner appeared signal Wait it back to mobile home page , Wait signal to appear. (PS: Under this mode, if “no serve” appeared, enter into SIM card application menu, press “Regain SIM Signal”to acquire signal). |
11-02-2019, 10:27 | #4 (permalink) |
Member: 1907775 Status: Offline Sonork: 1653265:unlocker Thanks Meter: 2,693 | 2.TMSI MANUAL MODE Apply to choose carrier TMSI manual unlocking mode (Detailed operations please refer to manual unlocking video) Choose Carrier Choose TMSI MANUAL Pop out ICCID input menu ( No need to revise ICCID, use Default ) Press Send mobile enter into following image Enter into SIM Card application press “Regain SIM Signal” wait signal and “3G” symbol appeared, dial “112” immediately, as following pic Do not hang up after dialing “112”, Pull out card and insert it, wait for signal to appear. Type 3 Unlocking Mode: ICCID unlocking mode ( USA use only, perfect unlocking ) Pop out unlocking mode menuā Choose ICCID UNLOCK Input Valid ICCID CODE Moible Power off and then start mobile,activate mobile and wait signal to appear ( USA use only, perfect unlocking ) |
The Following User Says Thank You to kinglock For This Useful Post: |
