Avengers Box (Multi Unlocker Box) |
05-06-2018, 16:59 | #1 (permalink) |
Freak Poster Join Date: Oct 2017 Location: pakistan
Member: 2767415 Status: Offline Thanks Meter: 30 | huawei lua-u22 flashing error log Flash files count is :14 Action : Firmware update. Selected Model: Huawei: Ascend Y3 II[LUA-U22] Exe version: Avengers Box MTK 0.5.0 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM316) Boot mode: Preloader Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6582 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) HYNIX 0x483847316505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A483847316505 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM61) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. [6102]Error: S_SECURITY_SEC_CFG_EXT_REGION_SPACE_OVERFLOW Wait untill phone will start charging. All done. |
05-06-2018, 19:16 | #8 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | To service phones you must know how phones work and find way to solve phones problem. Problems can be multiple, software or hardware. You must know how to perform phone diagnostic, to find and solve different software or hardware problems. Nobody can make this remote, this you must make yourself. In this specific case, firmware what you want to flash is not accepted by phone. To fix this, you must find and flash corect firmware. This is your problem with incorect used firmware, and really is not posible to fix exe to flash wrong firmware in your phone. |
05-06-2018, 21:20 | #9 (permalink) |
Member: 2767415 Status: Offline Thanks Meter: 30 | sir i can write same build number file but it still error recent i flash many phone with this file i can sent boot info log you send correct firmware in cm2 have hardware or emmc test to diagnostic bad dead or semi dead emmc before flash we cheak then flash but avenger have no emmc test |
05-06-2018, 22:52 | #10 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
I'am already told you, take debug log and check where is problem exactly. Make security backup, open with hexeditor proinfo and check exactly your model. If you more like other tool, use other tool, really not understand your problem. Our tool also have all posible instruments to identify problem, depend if you want or not to use this. I'am already told you this many times and this start to be offtopic already. More, we provide you instrument, but we really can't provide you gsm repair learning school. We not have this service. | |
05-07-2018, 16:07 | #15 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Instead of checking debug log and see where is really problem with this phone and solve it, we have 13 posts with totally offtopic contents. Will sugest to topic starter to use google and to learn little about how gsm phones work. Without this is really not posible to do some with modern phones. Will close this topic now. |
