Avengers Box (Multi Unlocker Box) |
05-11-2018, 11:13 | #1 (permalink) |
Freak Poster Join Date: Oct 2017 Location: pakistan
Member: 2767415 Status: Offline Thanks Meter: 30 | Huawei lua-u22 flashing error Flash files count is :14 Action : Firmware update. Selected Model: Huawei: Ascend Y3 II[LUA-U22] Exe version: Avengers Box MTK 0.5.0 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM187) Boot mode: Preloader Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6582 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) HYNIX 0x483847316505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A483847316505 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM61) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... [6126]Error: S_SECURITY_SECRO_HASH_INCORRECT Wait untill phone will start charging. All done. |
05-11-2018, 15:03 | #3 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | You must flash factory firmware and you must perform full flash or full erase + full flash(make security backup before) Your preloader and your secro differ(differ rsa sign) and exe give you warning about. Even if you will succed somehow to write this firmware in phone, result will be dead phone. This is very old and well known issue on huawei phones, strange how you not know about. |
05-11-2018, 18:14 | #5 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | many stuck on logo phones have damaged hardware. You must check first if problem come from hardware or from firmware. If problem come from hardware, need to fix hardware first. |
