Avengers Box (Multi Unlocker Box) |
08-01-2018, 16:24 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | is my fault or Avengers I did frp reset with Avenger and now my phone is just restarting again and again. What i must do it. and i found only one log in folder \[0000001] [14:59:26:828301] [Tid0x000016bc] [debug] -->[C1] DL_SetPacketLength #(api.cpp, line:2613) [0000002] [14:59:26:859501] [Tid0x000016bc] [debug] <--[C1] DL_SetPacketLength [0000003] [14:59:46:169939] [Tid0x00001368] [debug] -->[C2] FlashTool_Connect_BROM_Ex #(api.cpp, line:1876) [0000004] [14:59:46:169939] [Tid0x00001368] [debug] bCheckScatter: 0 #(api.cpp, line:1877) [0000005] [14:59:46:169939] [Tid0x00001368] [debug] Not load scatter yet #(api.cpp, line:1904) [0000006] [14:59:46:762339] [Tid0x00001368] [debug] chip: MT6737M #(api.cpp, line:1927) [0000007] [14:59:46:762339] [Tid0x00001368] [debug] used lib version: 1 #(api.cpp, line:1932) [0000008] [14:59:46:762339] [Tid0x00001368] [debug] <--[C2] FlashTool_Connect_BROM_Ex [0000009] [14:59:46:762339] [Tid0x00001368] [debug] -->[C3] FlashTool_GetBootResult #(api.cpp, line:1983) [0000010] [14:59:46:762339] [Tid0x00001368] [debug] <--[C3] FlashTool_GetBootResult [0000011] [14:59:46:762339] [Tid0x00001368] [debug] -->[C4] FlashTool_Connect_Download_InitDA #(api.cpp, line:2033) [0000012] [14:59:47:136740] [Tid0x00001368] [debug] <--[C4] FlashTool_Connect_Download_InitDA [0000013] [14:59:47:136740] [Tid0x00001368] [debug] -->[C5] FlashTool_Connect_Download_LoopDA #(api.cpp, line:2058) [0000014] [14:59:49:024343] [Tid0x00001368] [debug] <--[C5] FlashTool_Connect_Download_LoopDA [0000015] [14:59:49:039943] [Tid0x00001368] [debug] -->[C6] FlashTool_Readback #(api.cpp, line:1323) [0000016] [14:59:49:055543] [Tid0x00001368] [debug] <--[C6] FlashTool_Readback [0000017] [14:59:49:055543] [Tid0x00001368] [debug] -->[C7] FlashTool_WriteFlashMemory #(api.cpp, line:1393) [0000018] [14:59:49:071143] [Tid0x00001368] [debug] <--[C7] FlashTool_WriteFlashMemory [0000019] [14:59:49:071143] [Tid0x00001368] [debug] -->[C8] FlashTool_EnableWatchDogTimeout #(api.cpp, line:1220) [0000020] [14:59:49:071143] [Tid0x00001368] [debug] <--[C8] FlashTool_EnableWatchDogTimeout [0000021] [14:59:49:071143] [Tid0x00001368] [debug] -->[C9] FlashTool_Disconnect #(api.cpp, line:1033) [0000022] [14:59:49:102344] [Tid0x00001368] [debug] <--[C9] FlashTool_Disconnect |
08-01-2018, 17:08 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | In settings you have to open backup directory function, where usually is stored saved backups, logs so on. If you not modified storing path, it must be in my documents\Androidmtk FRP reset was ok or was displayed some error? Also, on some phones need to perform wipe also after frp reset. Also, phone can be with damaged filesystem , and now after reset frp, it trying to start and can't. Usually "only frp" reset is safe, and must be ok, if not exists another problems with phone. |
The Following User Says Thank You to orbita For This Useful Post: |
08-01-2018, 21:58 | #3 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Hisense_T5_Plus_V2.0_20170811-MT6737-7.1.zip was uploaded in support. |
08-02-2018, 10:06 | #5 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Here is Flashing log Action : Firmware update. Selected Model: 0-By CPU: ELBRUS Exe version: Avengers Box MTK 0.5.3 Scenario: [5]Full format + Full Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM86) Boot mode: Preloader Using Algo 2. Scatter file loaded, not need emmi. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (116Gb+8192Mb) SAMSUNG 0x464531324d42 EMMC FW VERSION: 0d:00:00:00:00:00:00:00 EMMC CID: 150100464531324D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : DA USB VCOM Port (COM76) Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. FORMAT EMMC FLASH : BEGIN: 0x0 - LEN: 0x3a3e00000 Send preloader... Download firmware to flash now... Wait untill phone will start charging. All done. and here is origional file name that i readed after frp MT6737M_Hisense_T5_Plus_Hisense T5 Plus_HS6737MT_7.0_Hisense_alps-mp-n0.mp1-V1.0.2_mlt6737m.35g.n_P29_2018-08-01 22_06_36 |
08-02-2018, 11:36 | #6 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | MTK phones usually not have problems with downgrade. Except some brands like sony and posible nokia. So this message gived by other box, most posible is not important. You maked full flash+ full format, in this case phones with working hardware must start ok. Most posible you have hardware problems in phone. More, from what i'am see, you use generic settings, this meen phone is not secured. In this phone will work even readed firmware from other phone or restoring backup if you maked. But mostly sure here is another problem. |
