Avengers Box (Multi Unlocker Box) |
01-12-2020, 12:09 | #1246 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Q Infinity D Frp Code: Exe version: Avengers Box MTK 0.6.5 Selected model: Qmobile Q Infinity D [auto]Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM3) Boot mode: Preloader BBCHIP: 6580 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) HYNIX 0x483847346132 EMMC FW VERSION: a5:00:00:00:00:00:00:00 EMMC CID: 90014A483847346132 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2c00000 [7.293 GB] Checking data, wait... Writing FRP, wait... FRP Reset Done. Wait untill phone will start charging. [0]All done. |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
01-12-2020, 12:22 | #1247 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Motorola XT1723 Frp Code: Exe version: Avengers Box MTK 0.6.5 Selected model: Motorola XT1723 [auto]Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM3) Boot mode: Preloader BBCHIP: 335 0 ca00 Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (116Gb+8192Mb) SAMSUNG 0x464531324d42 EMMC FW VERSION: 0d:00:00:00:00:00:00:00 EMMC CID: 150100464531324D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Checking data, wait... Writing FRP, wait... FRP Reset Done. Wait untill phone will start charging. [0]All done. |
01-14-2020, 06:13 | #1248 (permalink) |
Freak Poster Join Date: Jan 2018
Member: 2798902 Status: Offline Thanks Meter: 11 | Repair IMEI in BLU Life, Studio, etc.. with Avengers Box Module MTK - Flash Mode - Without ROOT. Mobile BLU, with Invalid, damaged or Null IMEI, in this case there was no way to restore it by any other method that had and had Bootloop failure in the attempt, with Bootloader Locked. 1. Turn on the Mobil and Enable USB Debugging in the Terminal (if you have access). 2. Execute the Avengers MTK Module 3. Select CPU and MT6582 (1), undo all the Options (2), Select Flash Connection (3), write our serials correctly (4), and click on Repair IMEI (5). 4. With the Terminal turned off and with a full charge battery, we connect the Terminal directly to the USB without BootKey. 5. We hope that the action ends, it will create a backup file “nvram.bin” with the f4 already repaired as backup and will save them in the default route of the program in ZIP format. Example: C: \ Users \ UsersXXX \ Documents \ Android_MTK \ nvram_backup \ FLASH_MODE_NVRAM_MT6582_3537900648XXXXX_3537900649 XXXXX_10_11_2019.zip 6. Unzip the ZIP, extract the file and copy it (replace if it exists) in our ROM Firmware Stock where all the partition files + the Scatter file. 7. Now we have to open the scatter file “Scatter.txt” found in our Firmware Stock ROM with a text editor and modify or fix the lines corresponding to the file (NVRAM.BIN), it has to be as follows way for Example (in other models the size of the partitions may vary): - partition_index: SYS4 partition_name: NVRAM file_name: nvram.bin is_download: true type: NORMAL_ROM linear_start_addr: 0x1800000 physical_start_addr: 0x400000 partition_size: 0x500000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: BINREGION reserve: 0x00 8. Now we flash our ROM Firmware, with SP Flash Tools 5.1343.01, or with the same Avengers or NCK, but we make sure that the created file “nvram.bin” is selected in the list of SP Flash Tools scatter program. 9. Flashing in the classic way with SP Flash Tools. 10. Enjoy! .................................................. .................................................. ... LogInfo: Selected connection Metod: Flash Connection Exe version: Avengers Box MTK 0.6.2 Selected phone: MT6582 Action : IMEI REPAIR. IMEI[1] for write : 3537900XXXXXXXX IMEI[2] for write : 3537900XXXXXXXX Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM43) Boot mode: Preloader BBCHIP: 6582 1 ca01 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6582 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x4b3758564d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1501004B3758564D42 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] High speed disabled by user, continue with this settings. Dumping data, wait. Reading imei IMEI[1]: 3537900XXXXXXXX IMEI[2]: 3537900XXXXXXXX Backup saved: C:\Users\GabrielCh\Documents\Android_MTK\nvram_bac kup\FLASH_MODE_NVRAM_MT6582_353790064878837_353790 064928889_10_11_2019_12_59_47.zip Writing imei IMEI[1] TO UPDATE: 3537900XXXXXXXX IMEI[2] TO UPDATE: 3537900XXXXXXXX Generic IMEI OK Wait untill phone will start charging. [0]All done. .................................................. .................................................. ... CAPTURE: https://prntscr.com/qnchum |
01-14-2020, 12:35 | #1249 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Alcatel 1 [5033x] simlock done Exe version: Avengers Box MTK 0.6.6 Selected model: Alcatel OT-5033X Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM5) Boot mode: Brom Phone detected...Please wait BBCHIP: 6739 2 cb00 Using Algo 5. Helio MT6739 phone detected, swithing to helio api Loading emmi from database Helio enabled DRAM in First Da: TRUE Sending loader..... BBCHIP MT6739 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 150100464E3632 : 000000000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM8) Phone have OTP partition. MODEL FROM PROINFO: 5033X-2AVDGB2 SECRO FROM PROINFO: X7L0FC01CT10 OTP IMEI: 356270092572154 Modem version: MOLY.LR12A.R2.MP.V18.P121 Starting alcatel helio Simlock, not disconnect phone untill done [--0] writing to simlock [--0] writing to tctpersist [helio]Wait untill phone will start charging. [0]All done. |
01-17-2020, 13:35 | #1250 (permalink) |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | Q Mobile Reset Password With out Data Lose. Exe version: Avengers Box MTK 0.6.6 Selected model: 0-By CPU ELBRUS Action: Reset Pattern Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM8) Boot mode: Preloader BBCHIP: 6572 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 05:00:00:00:00:00:00:00 EMMC CID: 90014A483447316404 : 00000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM158) [1]locksettings.db erased ok [1]locksettings.db-wal erased ok [1]locksettings.db-shm erased ok [1]password.key erased ok [1]gesture.key erased ok If phone remain on logo, repower phone again. If lock remain, perform 2 times reset without power on phone. Wait untill phone will start charging. [0]All done. |
The Following User Says Thank You to ahmer5050 For This Useful Post: |
01-20-2020, 16:35 | #1260 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Oppo F1 Code: Action : Meta Info. Selected Model: 0-By CPU:ELBRUS Exe version: Avengers Box MTK 0.6.6 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [7]Detected: MediaTek USB Port_V1632 (COM7) \\?\usb#vid_0e8d&pid_0003#6&90e9f40&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [8]META Port Detected: MediaTek PreLoader USB VCOM_V1632 (Android) (COM8) USB\VID_22D9&PID_0006\6&90E9F40&0&6 Start sync target, waiting responce..... ChipID: MT6750,S01 [MT6750,S01]Using Algo 3 Brand: OPPO Board: full_oppo6750_15331 Model: A1601 Name: A1601 Release: A1601EX_11_A.41_191226 Version: 5.1 Mediatek Version: A1601EX_11_A.41_191226 Branch: L1.MP10.TC16SP Platform: MT6755 Reading imei IMEI[1]: xxxxxxxxxxx IMEI[2]: xxxxxxxxxxx Modem Version: LR11.W1539.MD.MP OPPO6755_15331_66 [0]All done. Action : Reset to factory default. Selected Model: 0-By CPU:ELBRUS Exe version: Avengers Box MTK 0.6.6 Scanning for presents meta ports... Detected(8) : MediaTek PreLoader USB VCOM_V1632 (Android) (COM8) Start sync target, waiting responce..... ChipID: MT6750,S01 [MT6750,S01]Using Algo 3 Resetting phone step 1, wait.... Resetting phone step 2, wait.... ClearValue ok. FormatTCard ok. [0]All done. |
The Following 3 Users Say Thank You to mbiborna For This Useful Post: |
