Avengers Box (Multi Unlocker Box) |
05-14-2016, 11:45 | #151 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Samsung Galaxy S4 GT-i9505 Update lollipop Successfully Done, Feel The Power .:: BY ::. ..::: Avengers Box :::.. [IMG]****************************/convkey/13ae/zse910ieamali9z6g.jpg[/IMG] |
The Following User Says Thank You to kabul For This Useful Post: |
05-15-2016, 12:53 | #152 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 34
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | QMobile A6 Hang on Noir Logo has been wiped & repaired successfully Code: Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM25) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6575_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (28Gb+4096Mb) HYNIX 0x2058494e5948 EMMC FW VERSION: 15:00:00:00:00:00:00:00 EMMC CID: 90014A2058494E : 000000000000000000 EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe7600000 [3.615 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM26) Detecting format adress....wait! FORMAT EMMC FLASH : BEGIN: 0x224e4000 - LEN: 0x20100000 FORMAT EMMC FLASH : BEGIN: 0x425e4000 - LEN: 0x20100000 Phone can start slow at first power on If phone stuck on logo, perform wipe from recovery. First start can take up to 5 min on some phones. Wait untill phone will start charging. All done. |
The Following User Says Thank You to EjazATF For This Useful Post: |
05-15-2016, 12:59 | #153 (permalink) |
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | QMobile A8 Success Flashing Using Avengers Code: Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM25) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6575_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (28Gb+4096Mb) HYNIX 0x2058494e5948 EMMC FW VERSION: 15:00:00:00:00:00:00:00 EMMC CID: 90014A2058494E : 000000000000000000 EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe7600000 [3.615 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM (Android) (COM26) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. |
05-15-2016, 15:48 | #154 (permalink) |
Freak Poster Join Date: Jul 2012 Location: karachi Age: 31
Member: 1779651 Status: Offline Sonork: 100.1603336 Thanks Meter: 97 | g five smart 1 hang on logo done g five smart 1 succes flash with avanger box BR. USMAN SOFTWARE |
The Following User Says Thank You to s a dot com For This Useful Post: |
05-17-2016, 18:04 | #155 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile Noir X2 NAND Hang Logo & Restart Recovery Successfully Done, Feel The Power Time 01:18" .:: BY ::. [IMG]****************************/convkey/a2fb/i4id4p0u0gmlkd96g.jpg[/IMG] Meta info [IMG]****************************/convkey/13ae/zse910ieamali9z6g.jpg[/IMG] |
05-17-2016, 18:14 | #156 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile Noir X25 Camera Open Gallery Error Recovery Successfully Done, Feel The Power Time 02:15" .:: BY ::. [IMG]****************************/convkey/a2fb/i4id4p0u0gmlkd96g.jpg[/IMG] Meta info [IMG]****************************/convkey/13ae/zse910ieamali9z6g.jpg[/IMG] |
05-17-2016, 18:21 | #157 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Tab Q400 Hang Logo Recovery Successfully Done, Feel The Power Time 02:30" .:: BY ::. [IMG]****************************/convkey/a2fb/i4id4p0u0gmlkd96g.jpg[/IMG] Meta info [IMG]****************************/convkey/13ae/zse910ieamali9z6g.jpg[/IMG] |
05-17-2016, 18:28 | #158 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Samsung Galaxy J5 Duos SM-J500H Remove Pattern Just Factory Reset Successfully Done, Feel The Power .:: BY ::. [IMG]****************************/convkey/a2fb/i4id4p0u0gmlkd96g.jpg[/IMG] [IMG]****************************/convkey/13ae/zse910ieamali9z6g.jpg[/IMG] |
05-18-2016, 07:30 | #159 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Samsung Galaxy Grand Prime SM-G530H Remove Pin Lock Just Factory Reset Successfully Done, Feel The Power .:: BY ::. [IMG]****************************/convkey/a2fb/i4id4p0u0gmlkd96g.jpg[/IMG] [IMG]****************************/convkey/13ae/zse910ieamali9z6g.jpg[/IMG] NCK Team Powered By Fast Unlocking Ltd. NCK Dongle - NCK Box - Cellular Codes - Avengers Box - UMT Box |
05-18-2016, 07:45 | #160 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile Noir X6 NAND Hang Logo Recovered & invalid imei Successfully Done, Feel The Power Time .:: BY ::. [IMG]****************************/convkey/a2fb/i4id4p0u0gmlkd96g.jpg[/IMG] invalid imei Repair Done Meta info [IMG]****************************/convkey/13ae/zse910ieamali9z6g.jpg[/IMG] NCK Team Powered By Fast Unlocking Ltd. NCK Dongle - NCK Box - Cellular Codes - Avengers Box - UMT Box |
05-18-2016, 08:26 | #161 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Samsung Galaxy Core Prime SM-G360H Clone All Apps Not Opening Recovered Successfully Done, Feel The Power Time .:: BY ::. [IMG]****************************/convkey/a2fb/i4id4p0u0gmlkd96g.jpg[/IMG] Meta info [IMG]****************************/convkey/13ae/zse910ieamali9z6g.jpg[/IMG] NCK Team Powered By Fast Unlocking Ltd. NCK Dongle - NCK Box - Cellular Codes - Avengers Box - UMT Box |
05-18-2016, 09:19 | #163 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Samsung Galaxy J1 SM-J100H Clone Hang Logo Just Format Successfully Done, Feel The Power Time 00:12" .:: BY ::. [IMG]****************************/convkey/a2fb/i4id4p0u0gmlkd96g.jpg[/IMG] Meta info [IMG]****************************/convkey/13ae/zse910ieamali9z6g.jpg[/IMG] NCK Team Powered By Fast Unlocking Ltd. NCK Dongle - NCK Box - Cellular Codes - Avengers Box - UMT Box |
05-18-2016, 09:52 | #164 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Calme Spark S12 SC7715 Remove Pin Lock Just Factory Reset Successfully Done, Feel The Power .:: BY ::. [IMG]****************************/convkey/a2fb/i4id4p0u0gmlkd96g.jpg[/IMG] [IMG]****************************/convkey/13ae/zse910ieamali9z6g.jpg[/IMG] NCK Team Powered By Fast Unlocking Ltd. NCK Dongle - NCK Box - Cellular Codes - Avengers Box - UMT Box |
05-18-2016, 10:09 | #165 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile Noir i6 Wifi & Mobile Data Turns On Automatically Recovered Successfully Done, Feel The Power Time 04:16" .:: BY ::. [IMG]****************************/convkey/a2fb/i4id4p0u0gmlkd96g.jpg[/IMG] Meta info [IMG]****************************/convkey/13ae/zse910ieamali9z6g.jpg[/IMG] NCK Team Powered By Fast Unlocking Ltd. NCK Dongle - NCK Box - Cellular Codes - Avengers Box - UMT Box |
