Avengers Box (Multi Unlocker Box) |
07-31-2019, 09:54 | #1172 (permalink) |
Freak Poster Join Date: May 2014 Location: Africa
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | Ulnlock Zte Z815 done Exe version: Avengers Box MTK 0.6.2 Selected model: Zte T815 Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM46) Boot mode: Preloader BBCHIP: 6572 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) HYNIX 0x483447326111 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 90014A483447326111 : 00000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM137) IMEI[1]: 86866************ IMEI[2]: 868************** Reading security, wait... SIM[1]: Block1(N): Locked (remain:0) Code : 226406475884 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked SIM[2]: Block1(N): Locked (remain:10) Code : 226406475884 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked [2060]Unlocking target...please wait [0]Unlock finished. [1]Unlock finished. CHK updated ok. Wait untill phone will start charging. [0]All done. |
The Following User Says Thank You to elykia For This Useful Post: |
08-01-2019, 15:07 | #1173 (permalink) |
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | ZTL RIGEL stuck logo done EXE: Avengers Spreadtrum Module 1.0 SELECTED: SC7731G_EMMC 4.x ACTION: Format Userdata(misc) Start Detect phone... Detected: SPRD U2S Diag (COM138) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. FileSystem: EMMC Manufacturer: ZTL Hardware: skytek_s08 Platform: sc8830 Board: skytek_wg4030s Build Id: ZTL_RIGEL-2015.08.10 Model: ZTL RIGEL Android Release: 4.4.2 Android Version: ZTL_RIGEL-2015.08.10 Country: PT [misc]Formating userdata, wait... Format OK. Wait untill phone will restart. Total Time: 00:00:28 Done. |
08-02-2019, 11:06 | #1174 (permalink) |
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | EXE: Avengers Spreadtrum Module 1.0 SELECTED: SC6531EFM ACTION: Read PhonePassword Start Detect phone... Detected: SPRD U2S Diag (COM138) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.2 Changing bautrate OK. Send Second Loader. Flash ID: [EF4016] WINBOND: [0x400000]W25Q32FV size: 0x400000 SN: 14984819722404 EFS Start: 3D0000 Size: 0x30000 IMEI 1: 359591086800468 IMEI 2: 359591086880460 [4][218]Password: 1234 [4][2DA][active]Paasword: 1966 [4][2DB]Password: 1234 Total Time: 00:00:23 Done. |
08-02-2019, 11:09 | #1175 (permalink) |
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | Azumi l2z read code.... Done successful EXE: Avengers Spreadtrum Module 1.0 SELECTED: SC6531EFM ACTION: Read PhonePassword Start Detect phone... Detected: SPRD U2S Diag (COM138) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.2 Changing bautrate OK. Send Second Loader. Flash ID: [EF4016] WINBOND: [0x400000]W25Q32FV size: 0x400000 SN: 14984819722404 EFS Start: 3D0000 Size: 0x30000 IMEI 1: 35959108******* IMEI 2: 3595910******** [4][218]Password: 1234 [4][2DA][active]Paasword: 1966 [4][2DB]Password: 1234 Total Time: 00:00:23 Done. |
08-02-2019, 11:22 | #1176 (permalink) |
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | SAMSUNG CLONE Reset Privacy DONE Exe version: Avengers Box MTK 0.6.2 Selected model: 0-By CPU ELBRUS Action: Reset Privacy Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM46) Boot mode: Preloader BBCHIP: 6572 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 256 MB DRAM ---------------------------------------------------- NAND: (4Gb+2048Mb) [SAMSUNG] KA100O015B_BJTT BOOT STYLE : NAND BOOT Size: 0x20000000 [0.500 GB] BlockSize: 0x20000 PageSize: 0x800 SpareSize: 0x40 Searching partiton table, wait.. Offset: 0x1f5e0000 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM137) Dumping data, wait. Value found, processing[010c][00260000] Resetting phone. [1]FORMAT - BEGIN: 0x18dc0000 - LEN: 0x700000 [1]FORMAT - BEGIN: 0x194c0000 - LEN: 0x6100000 Wait untill phone will start charging. [0]All done. |
08-05-2019, 08:56 | #1177 (permalink) |
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | Alcatel Generic OT233 calculator code Exe Version: Avengers Tool v2.9 Brand: Alcatel Generic Model: OT233 IMEI :867425********* Checking server, wait... PID: VDPT1(XFB1FG30) NCK : 3789812556 NSCK: 3270323955 SPCK: 3528156567 SIM : 0305114404 CORPORATE: 2616577138 Calculated by Avengers Server. !!!!Do not use this calculator for free codes distribution. !!!! !!!!This violate our Terms of Use and card can be blocked. !!!! PID: VDPT1(XFB1FG30) NCK : 3789812556 NSCK: 3270323955 SPCK: 3528156567 SIM : 0305114404 CORPORATE: 2616577138 Calculated by Avengers Server. !!!!Do not use this calculator for free codes distribution. !!!! !!!!This violate our Terms of Use and card can be blocked. !!!! |
08-05-2019, 13:48 | #1178 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Vivo:Y91C new Pattern Reset Done Action : Reset to factory default. Selected Model: Vivo:Y91C new Exe version: Avengers Box MTK 0.6.2 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [264]Detected: MediaTek PreLoader USB VCOM (Android) (COM264) \\?\usb#vid_0e8d&pid_2000#5&ccb68e8&1&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [269]META Port Detected: MediaTek DA USB VCOM (Android) (COM269) USB\VID_0E8D&PID_2007\5&CCB68E8&1&8 Start sync target, waiting responce..... ChipID: MT6765,S01 Using Algo 5. Resetting phone step 1, wait.... Resetting phone step 2, wait.... ClearValue ok. FormatTCard ok. [helio]Wait untill phone will start charging. [0]All done. |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
08-09-2019, 13:04 | #1179 (permalink) |
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | Hotwav venus R7 write imei done just 5 sec Action: REPAIR. Detecting phone, wait... Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Making 10 sec timeout.. Detected: SPRD U2S Diag (COM115) Readed IMEI 1: 35193409******* Readed IMEI 2: 35193409114**** IMEI 1 to write: 351934********* IMEI 2 to write: 3519340******** Write IMEI Done. Done. |
08-11-2019, 12:28 | #1180 (permalink) |
No Life Poster Join Date: Jul 2015 Location: INDIA Age: 34
Member: 2431049 Status: Offline Sonork: 100.1680262:hunnyck Thanks Meter: 966 | gione P4 Password reset done without loss data Exe version: Avengers Box MTK 0.5.9 Selected model: 0-By CPU ELBRUS Action: Reset Pattern Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM84) Boot mode: Preloader BBCHIP: 6582 1 ca01 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6582 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (58Gb+8192Mb) SAMSUNG 0x4b3758564d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 1501004B3758564D42 : 00000000000000 EMMC UA SIZE: 0x1d2000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x1d2880000 [7.290 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM85) [1]locksettings.db erased ok [1]locksettings.db-wal erased ok [1]locksettings.db-shm erased ok [1]gesture.key erased ok If phone remain on logo, repower phone again. If lock remain, perform 2 times reset without power on phone. Wait untill phone will start charging. All done. |
The Following 2 Users Say Thank You to hunnyck For This Useful Post: |
