Avengers Box (Multi Unlocker Box) |
04-24-2022, 08:15 | #1456 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | G'FIVE G4 Play Factory Reset Done :) Code: Action: Reset Phone. Detecting phone, wait... Using connection mode 1 Detected: SPRD U2S Diag (COM13) E301_XYZN_P2_GFIVE_G4 play_V03_20200102 Project Version:SC6531EFM_BAR BASE Version: BASE_SVN HW Version:SC6531EFM_BAR 01-02-2020 17:25:06 IMEI 1: 35241211016xxxx IMEI 2: 35241211068xxxx IMEI 3: 35857001010xxxx IMEI 4: 91057560140xxxx DONE DONE DONE DONE Reset done, phone must restart. Done. Exe version: Avengers Spreadtrum Module 2.1.2 Log saved: C:\Users\Syed Mobile\Documents\spreadtrum_module\Saved_Logs\_35241211016xxxx_diag_reset_phone.txt |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
04-25-2022, 07:58 | #1457 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | QMobile Q130i Reset User Code Done :) Code: EXE VERSION: Avenger MTK Tool 0.3 Connect phone in boot mode ... USB\VID_0E8D&PID_0003&REV_0100 Com port ok : COM4 Phone detected...Please wait Conected ok with target ... Reopen comport(COM4) BaseBand CPU : MT6261 SW_VER : QMobile_Q130i_V07_19_03_20 HW_VER : FISE61M_11C_HW Meta mode conected ok, start reading phone.... User code(Active) : 687526 User code reset :OK META END OK. All done. |
04-26-2022, 07:24 | #1458 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Welcome V11 Read Factory Firmware Done :) Code: Action : Read Firmware. Selected 0-By CPU:MT6572 Exe version: Avengers Box MTK 0.7.9 Phone must be off with battery inside. Battery must be charged Please insert USB cable now... For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(7) : MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) [7] \\?\usb#vid_0e8d&pid_2000#6&3a34e632&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Preloader BBCHIP: 6572 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 05:00:00:00:00:00:00:00 EMMC CID: 90014A483447316404 : 00000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(16) : MediaTek DA USB VCOM (Android) (COM16) [16] \\?\usb#vid_0e8d&pid_2001#6&3a34e632&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Build ID: KOT49H Display ID: ALPS.KK1.MP7.V1.7 Version: 4.4.2 Build Date: Tue Aug 22 22:24:26 CST 2017 Model: V11 Brand: welcome Device: V11 Manufacturer: V11 Region: US Mediatek Version Release: ALPS.KK1.MP7.V1.7 IMEI[1]: xxxxxxxxxxxxxxxxx IMEI[2]: xxxxxxxxxxxxxxxxx Start dumping flash, this can take up to 1 hour....... Dumping Preloader. Partition: PRELOADER Partition: MBR Partition: EBR1 Partition: PRO_INFO Partition: NVRAM Partition: PROTECT_F Partition: PROTECT_S Partition: SECCFG Partition: UBOOT Partition: BOOTIMG Partition: RECOVERY Partition: SEC_RO Partition: MISC Partition: LOGO Partition: EXPDB Partition: ANDROID Partition: CACHE Partition: USRDATA Partition: BMTPOOL Start processing MBR MBR Reading: BEGIN: 0xc00000 - LEN: 0x80000 Start processing EBR1 EBR1 Reading: BEGIN: 0xc80000 - LEN: 0x80000 Start processing nvram.bin ...... Reading: BEGIN: 0x1000000 - LEN: 0x500000 Start processing protect1.img ...... Reading: BEGIN: 0x1500000 - LEN: 0xa00000 Start processing protect2.img ...... Reading: BEGIN: 0x1f00000 - LEN: 0xa00000 Start processing UBOOT lk.img Start processing BOOTIMG boot.img Reading boot.img Start processing RECOVERY recovery.img Reading recovery.img Start processing SEC_RO secro.img Reading: BEGIN: 0x3580000 - LEN: 0x40000 Start processing LOGO logo.bin Start processing ANDROID system.img Reading: BEGIN: 0x4340000 - LEN: 0x32000000 Start processing CACHE cache.img Start processing USRDATA userdata.img Saved to : C:\ProgramData\Android_MTK_Backup_Folder\firmware_backup\MT6572_EMMC_V11_welcome__2022_04_26_11_18 Wait untill phone will start charging. [0]All done. |
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post: |
05-01-2022, 09:38 | #1459 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | OPPO CPH1923 A1K Factory Reset Done :) Code: Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: Avengers Box MTK 0.7.9 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(4) : MediaTek USB Port_V1632 (COM4) [4] \\?\usb#vid_0e8d&pid_0003#6&3a34e632&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6765 CPU code: 766 Target config: e5 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [3c200]Dumping phone preloader. Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader_backup\preloader_oppo6762_18540.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(4) : MediaTek USB Port_V1632 (COM4) [4] \\?\usb#vid_0e8d&pid_0003#6&3a34e632&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6765 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051443633 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Build ID: PPR1.180610.011 Version: 9 Manufacturer: OPPO This phone have FRP partition. Phone have OTP partition. Modem version: MOLY.LR12A.R2.PIE.P22.PR3.TC16.SP.V1.P4 [helio]Wait untill phone will start charging. [0]All done. Code: [OPPO MODE]Action: Reset To Factory. Selected 0-By CPU:ELBRUS Exe version: Avengers Box MTK 0.7.9 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(4) : MediaTek USB Port_V1632 (COM4) [4] \\?\usb#vid_0e8d&pid_0003#6&3a34e632&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6765 CPU code: 766 Target config: e5 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [3c200]Dumping phone preloader. Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader_backup\preloader_oppo6762_18540.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(4) : MediaTek USB Port_V1632 (COM4) [4] \\?\usb#vid_0e8d&pid_0003#6&3a34e632&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6765 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051443633 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Resetting userdata. [helio]Wait untill phone will start charging. [0]All done. Code: Exe version: Avengers Box MTK 0.7.9 Selected model: 0-By CPU ELBRUS [auto]Action: Reset FRP Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(4) : MediaTek USB Port_V1632 (COM4) [4] \\?\usb#vid_0e8d&pid_0003#6&3a34e632&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6765 CPU code: 766 Target config: e5 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [3c200]Dumping phone preloader. Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader_backup\preloader_oppo6762_18540.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(4) : MediaTek USB Port_V1632 (COM4) [4] \\?\usb#vid_0e8d&pid_0003#6&3a34e632&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6765 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051443633 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Phone have OTP partition. Modem version: MOLY.LR12A.R2.PIE.P22.PR3.TC16.SP.V1.P4 Starting helio frp, not disconnect phone untill done [HELIO][frp]Format partition, please wait... [0]FRP Reset Done. [helio]Wait untill phone will start charging. [0]All done. |
05-11-2022, 14:20 | #1460 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | VIVO Y81 Reset User Lock without Data Loss Done :) Code: Action : Boot Info. Selected Vivo:Y81 Exe version: Avengers Box MTK 0.7.9 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(4) : MediaTek USB Port_V1632 (COM4) [4] \\?\usb#vid_0e8d&pid_0003#6&3a34e632&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6765 CPU code: 766 Target config: e5 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [3d600]Dumping phone preloader. Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader_backup\preloader_k62v1_64_bsp.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(4) : MediaTek USB Port_V1632 (COM4) [4] \\?\usb#vid_0e8d&pid_0003#6&3a34e632&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6765 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A68423861 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Build ID: O11019 Display ID: O11019 release-keys Version: 8.1.0 Build Date: Sat Feb 27 20:52:58 CST 2021 Model: vivo 1808 Brand: vivo Device: PD1732F_EX Manufacturer: vivo Model: PD1732F_EX This phone have FRP partition. Phone have OTP partition. Modem version: MOLY.LR12A.R2.MP.V23.P211 [helio]Wait untill phone will start charging. [0]All done. Code: [VIVO MODE]Action: Reset To Factory. Selected Vivo:Y81 Exe version: Avengers Box MTK 0.7.9 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(4) : MediaTek USB Port_V1632 (COM4) [4] \\?\usb#vid_0e8d&pid_0003#6&3a34e632&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6765 CPU code: 766 Target config: e5 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [3d600]Dumping phone preloader. Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader_backup\preloader_k62v1_64_bsp.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(4) : MediaTek USB Port_V1632 (COM4) [4] \\?\usb#vid_0e8d&pid_0003#6&3a34e632&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6765 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A68423861 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Resetting userdata. [helio]Wait untill phone will start charging. [0]All done. |
The Following 4 Users Say Thank You to syed tuqeer For This Useful Post: |
06-03-2022, 06:02 | #1461 (permalink) |
Freak Poster Join Date: Aug 2010 Location: india, haryana,
Member: 1358048 Status: Offline Thanks Meter: 706 | Realme c21y frp reset Code: Unisoc ums512 First 16 bytes from public rsa key. DDDD8FCA96286736C489E3DEDE319F60 *************** Phone Storage: EMMC SELECTED: Realme C21Y ACTION: Erase FRP Loader format:NEW Start Detect phone. Phone must be off with battery inside. Insert USB cable. Detected: SPRD U2S Diag (COM12) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. *************** [S]Manufacturer: realme [S]Brand: realme [S]Device: RMX3261 [S]Model: RMX3261 Build ID: RP1A.201005.001 CPU arhitecture: arm64-v8a Build product name: S19610AA1 Build description: S19610AA1_ctcc-user 11 RP1A.201005.001 45417 release-keys Product name: RMX3261 Build Id: RP1A.201005.001 Android Release: 11 Android Version: RMX3261_11_A.61 Security patch: 2021-10-05 Removing frp, wait... Format OK. [can take 0-10 sec]Wait untill phone restart. Exe version: Avengers Spreadtrum Module 2.1.3 |
The Following User Says Thank You to skakroliya For This Useful Post: |
08-15-2022, 07:15 | #1462 (permalink) |
No Life Poster Join Date: Dec 2009 Location: pakistan
Member: 1189561 Status: Offline Thanks Meter: 743 | qmobile s8 hang logo Boot mode: Brom BBCHIP: 6580 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x514531334d42 EMMC FW VERSION: 0d:00:00:00:00:00:00:00 EMMC CID: 150100514531334D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(50) : MediaTek DA USB VCOM (Android) (COM50) [50] \\?\usb#vid_0e8d&pid_2001#6&27c7ce02&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Backup preloader saved in firmware directory. Starting flash. Send preloader... HINT: If phone stuck on logo, for some phones help factory reset. Select factory reset tab/reset to factory default. Wait untill phone will start charging. [0]All done. |
08-15-2022, 07:17 | #1463 (permalink) |
Member: 1189561 Status: Offline Thanks Meter: 743 | a37 hang logo done Exe Version: Avengers Qualcomm Module 0.13.2 Operation: Upgrade Searching for phone..... Qualcomm HS-USB QDLoader 9008 (COM8) detected. Hello received. HW ID: 00000000E1507000 MSM8916 PK HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F Checking database for suitable loader..... Arhitecture:32 bits [32]Sending loader, please wait.. Waiting for loader to start... [1] Send NOP ok, loader start. CPU: MSM8916 MaxPayloadSizeFromTargetInBytes: 4096 MaxPayloadSizeToTargetInBytes: 8192 Reading partition info, wait. Volume[0] Size: 14.68 GB Partitions count: 38 [0164639F]Userdata Size: 11.14 GB [FLASH][SKIP] name: modem [0]Writing: ddr Start: 262144 length: 64 [0]Writing: sec Start: 265280 length: 1 [0]Writing: sbl1 Start: 393234 length: 507 [0]Writing: sbl1bak Start: 394258 length: 507 [0]Writing: aboot Start: 524288 length: 1234 [0]Writing: abootbak Start: 526336 length: 1234 [0]Writing: rpm Start: 655360 length: 303 [0]Writing: rpmbak Start: 656384 length: 303 [0]Writing: tz Start: 657408 length: 953 [0]Writing: tzbak Start: 658432 length: 953 [0]Writing: hyp Start: 659456 length: 112 [0]Writing: hypbak Start: 660480 length: 112 [0]Writing: oppodycnvbk Start: 667648 length: 20480 [0]Writing: oppostanvbk Start: 688128 length: 20480 [0]Writing: logo Start: 708608 length: 31268 [0]Writing: boot Start: 786432 length: 43067 [0]Writing: recovery Start: 851968 length: 53155 [0]Sparse writing: system Total chunks: 4274 BlockSize: 4096 Sector Size: 512 [0]Sparse writing: cache Total chunks: 10 BlockSize: 4096 Sector Size: 512 [0]Sparse writing: persist Total chunks: 15 BlockSize: 4096 Sector Size: 512 [0]Writing: driver Start: 7277632 length: 46476 [0]Sparse writing: userdata Total chunks: 220 BlockSize: 4096 Sector Size: 512 [FLASH][SKIP] name: PrimaryGPT [FLASH][SKIP] name: BackupGPT Applying patch, wait... Restarting phone..... |
08-15-2022, 07:18 | #1464 (permalink) |
Member: 1189561 Status: Offline Thanks Meter: 743 | oppo a37 read patren done Exe Version: Avengers Qualcomm Module 0.13.2 Operation: Read Pattern Searching for phone..... Qualcomm HS-USB QDLoader 9008 (COM8) detected. Hello received. HW ID: 00000000E1507000 MSM8916 PK HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F Checking database for suitable loader..... Arhitecture:32 bits [32]Sending loader, please wait.. Waiting for loader to start... [1] Send NOP ok, loader start. CPU: MSM8916 MaxPayloadSizeFromTargetInBytes: 4096 MaxPayloadSizeToTargetInBytes: 8192 Reading partition info, wait. Volume[0] Size: 14.56 GB Partitions count: 38 [0160B39F]Userdata Size: 11.02 GB Manufacturer: OPPO Cpu: arm64-v8a Build Id: LMY47V Model: A37f Android Release: 5.1.1 Android Version: A37fEX_11_190711 Version Incremental: 1480422943 Config: diag,serial_smd,rmnet_bam,adb Security patch: 2018-03-01 1 2 3 4 5 6 7 8 9 Pattern: Pattern: 145632897 ************************************* HEX: C25A54048F4868D186F39858BB0E8B0BE20A2822 ************************************* Restarting phone..... ************************************* |
The Following User Says Thank You to M.AKHTER For This Useful Post: |
08-15-2022, 07:19 | #1465 (permalink) |
Member: 1189561 Status: Offline Thanks Meter: 743 | another oppo a37 reset patren lock Exe Version: Avengers Qualcomm Module 0.13.0 Operation: Factory Format Searching for phone..... Qualcomm HS-USB QDLoader 9008 (COM68) detected. Hello received. HW ID: 00000000E1507000 MSM8916 PK HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F Checking database for suitable loader..... Arhitecture:32 bits [32]Sending loader, please wait.. Waiting for loader to start... [1] Send NOP ok, loader start. CPU: MSM8916 MaxPayloadSizeFromTargetInBytes: 4096 MaxPayloadSizeToTargetInBytes: 8192 Reading partition info, wait. Volume[0] Size: 14.56 GB Partitions count: 38 [0160B39F]Userdata Size: 11.02 GB Manufacturer: OPPO Cpu: arm64-v8a Build Id: LMY47V Model: A37f Android Release: 5.1.1 Android Version: A37fEX_11_190711 Version Incremental: 1480422943 Config: diag,serial_smd,rmnet_bam,adb Security patch: 2018-03-01 Resetting cache , wait Total blocks 10 Resetting userdata , wait Total blocks 120 Factory reset done, wait untill phone start This can take up to 5 min on slow phones. Restarting phone..... |
08-18-2022, 17:14 | #1466 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,804 | nokia 105 TA 1174 PASSWORD LOCK READING DONE Phone Storage: NOR EXE: Avengers Spreadtrum Module 2.1.4 SELECTED: Nokia 105[TA-1174] ACTION: Read PhonePassword -Loader format:SECURE Start Detect phone. Phone must be off with battery inside. Long press boot key(key 7) and insert usb cable. On some phones need to press (key 7 and key 4) . Keep key untill boot complete. Detected: SPRD U2S Diag (COM26) BOOT: Sprdrrs12 Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.2 Changing bautrate OK. Send Second Loader. Reading phone structure. Signed loader structure found. Flash ID: [C86016] GigaDevice: [0x400000]GD25LQ32B size: 0x400000 SN: 5B51FEFLU EFS Start: 3A0000 Size: 0x60000 [5][D53]Password: 12345 [6][D81][active]Paasword: 332211 [4][2E6]Password: 1234 Exe version: Avengers Spreadtrum Module 2.1.4 Log saved: C:\Users\كفاح\Documents\spreadtrum_module\Saved_Lo gs\Nokia105[TA-1174]_5B51FEFLU_read_efs_info.txt Total Time: 00:00:23 Done. |
09-17-2022, 13:01 | #1467 (permalink) |
Freak Poster Join Date: May 2016 Location: MOZAMBIQUE
Member: 2576731 Status: Offline Thanks Meter: 72 | Hisense u50 hwcd104e frp reset sucessfull Spreadtrum SP7731e Board First 16 bytes from public rsa key. AD7E67E09F57F0A391493DE4F96FDFBC *************** Phone Storage: EMMC SELECTED: U964 ACTION: Erase FRP Loader format:NEW Start Detect phone. Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. Keep key untill boot complete. Detected: SPRD U2S Diag (COM15) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. UID: TB9M31_24_34_47 *************** Build ID: OPM2.171019.012 CPU arhitecture: armeabi-v7a Manufacturer: Hisense Hardware: sc7731e_fs288_v1.1.0 Hardware version: SC7731e_2_IRD_K_V1.1.0 Fota platform: Sprd7731_8.1 Build product name: sp7731e_fs288 Build description: sp7731e_fs288_project-user 8.1.0 OPM2.171019.012 26315 release-keys Product name: U605 Fota version: Hisense_HWCD104E_S03_03_01_ZA00 Board: Hisense_U605 Build Id: OPM2.171019.012 Model: Hisense U50 Android Release: 8.1.0 Android Version: Hisense_HWCD104E_S03_03_01_ZA00 Security patch: 2021-07-05 This phone have frp partition. Removing frp, wait... Format OK. [can take 0-10 sec]Wait untill phone restart. Exe version: Avengers Spreadtrum Module 2.1.3 |
10-04-2022, 11:54 | #1469 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Jazz Digit4G Crown factory Reset Done :) Code: Spreadtrum 9832e_1h10_32b Board First 16 bytes from public rsa key. AD7E67E09F57F0A391493DE4F96FDFBC *************** Phone Storage: EMMC SELECTED: SC9820E_EMMC_GENERIC [0]ACTION: Boot Info Loader format:NEW Start Detect phone. Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. Keep key untill boot complete. Detected: SPRD U2S Diag (COM55) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. UID: T4GP85_12_31_28 Manufacturer: sprd Hardware: sp9820e_1h10ll Platform: sp9820e Fota platform: SC9820E Build product name: sp9820e_1h10ll Build description: sp9820e_1h10ll_native-user 4.4.4 KTU84P eng.sz1002.20220121.145338 test-keys Product name: Digit4G Crown Board: sp9820e_1h10 Build Id: digitOS-V12-20220121 Model: Digit4G Crown Android Release: 4.4.4 Android Version: digitOS-V12-20220121 This phone have frp partition. CPU NAME: SC9832E NV partition: l_fixnv1 IMEI 1: 35339215034xxxx IMEI 2: 35339215034xxxx IMEI 3: 867400020316638 IMEI 4: 867400020316646 Simlock Type: 4 Simlock Status: SIMLOCK: ACTIVE NETWORK SUBNET: INACTIVE SP LOCK: INACTIVE CORPORATE: INACTIVE USER LOCK: INACTIVE [4]Simlock Type: 0 0 Phone have empty sign array, can be old security or erased nv. [can take 0-10 sec]Wait untill phone restart. Exe version: Avengers Spreadtrum Module 2.1.5 Code: Action: Reset Phone. Detecting phone, wait... Using connection mode 1 Detected: SPRD U2S Diag (COM55) Platform Version: MOCORTM_19A_W19.39.5_P2_Debug Project Version: sharkle_Feature_Phone BASE Version: FM_BASE_19A_W19.39.5_P2 HW Version: sc9820e_modem 12-04-2019 16:52:39 Build number: sp9820e_1h10ll_native-user 4.4.4 KTU84P eng.sz1002.20220121.145338 test-keys EMMC DDR SIZE :4MB+512MB UID: T4GP85_12_31_28 IMEI 1: 35339215034xxxx IMEI 2: 35339215034xxxx IMEI 3: 867400020316638 IMEI 4: 867400020316646 DONE DONE DONE DONE Done. Exe version: Avengers Spreadtrum Module 2.1.5 |
10-04-2022, 11:57 | #1470 (permalink) |
