Avengers Box (Multi Unlocker Box) |
05-25-2019, 12:56 | #1 (permalink) |
Freak Poster Join Date: Sep 2016 Location: Rawalpindi
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Qmobile Noir X1S Dead. Qmobile Noir X1S was dead by me. I have taken its back up with other tool(CM2). And can write that firmware by only that tool. But can not write with any other tool even with Avenger also. Please need urgent help. Flash files count is :12 Action : Firmware update. Selected Model: 0-By CPU: MT6735 Exe version: Avengers Box MTK 0.6.1 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MTK USB Port (COM206) Boot mode: Brom BBCHIP: 321 0 ca00 Using Algo 2. Scatter file loaded, not need emmi. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737T BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 3 GB DRAM ---------------------------------------------------- EMMC: (233Gb+24576Mb) SAMSUNG 0x475836424d42 EMMC FW VERSION: 03:00:00:00:00:00:00:00 EMMC CID: 150100475836424D42 : 00000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x748800000 [29.133 GB] Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM37) Backup preloader saved in firmware directory. Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Starting flash. [1003]Error: S_INVALID_BBCHIP_TYPE Wait untill phone will start charging. [0]All done. In qmobile this model Noir X1S is not in list. Thanks Br, Raja |
05-25-2019, 13:07 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Open scater with some text editor, notepad ++ for example. And check scater header, you must have some like this Code: - general: MTK_PLATFORM_CFG info: - config_version: V1.1.2 platform: MT6737T project: cereus storage: EMMC boot_channel: MSDC_0 block_size: 0x20000 Must be same with your phone cpu. This error meen Code: [1003]Error: S_INVALID_BBCHIP_TYPE |
The Following User Says Thank You to orbita For This Useful Post: |
05-25-2019, 14:03 | #3 (permalink) |
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Flash Done [QUOTE=orbita;13671533]Open scater with some text editor, notepad ++ for example. And check scater header, you must have some like this Code: - general: MTK_PLATFORM_CFG info: - config_version: V1.1.2 platform: MT6737T project: cereus storage: EMMC boot_channel: MSDC_0 block_size: 0x20000 Hi sir, Flashing done as per instruction but phone still sleeping. Flash files count is :13 Action : Firmware update. Selected Model: 0-By CPU: MT6737T Exe version: Avengers Box MTK 0.6.1 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM31) Boot mode: Preloader BBCHIP: 321 0 ca00 Using Algo 2. Scatter file loaded, not need emmi. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6737T BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 3 GB DRAM ---------------------------------------------------- EMMC: (233Gb+24576Mb) SAMSUNG 0x475836424d42 EMMC FW VERSION: 03:00:00:00:00:00:00:00 EMMC CID: 150100475836424D42 : 00000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x748800000 [29.133 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM37) Backup preloader saved in firmware directory. Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Starting flash. Wait untill phone will start charging. [0]All done. Where is fault by my side..... more help please Thanks Br, raja |
05-25-2019, 14:09 | #4 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Here can be 2 posible problems. Bad firmware ...or hardware damaged phone. Make security backup(just in case) and perform full erase + full flash. But you must agree with customer, if phone have hardware problems, you can have after totally dead phone. |
05-25-2019, 16:50 | #5 (permalink) |
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Hi sir, Now both firmware can be flashed ok....but phone is in same condition. backup firmware:- MT6737T__QMobile__Noir_X1S__Noir_X1S__7.0__SWW1627 QM_0402_T5343(CM2) Other Firmware:- QMobile_Noir_X1S_MT6737T_0402_T5485_08152017_7.0 Result is same. Phone is sleeping deep. Thanks Br, Raja |
05-25-2019, 16:57 | #6 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | If after flash condition is same, can be 2 things. Firmware is not ok or phone have problems with hardware. |
05-25-2019, 17:08 | #7 (permalink) |
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Hi sir, I have search every where but can not find DCC firmware for this Qmobile Noir X1S. Please any body have DCC firmware for this model. need it urgent. Thanks Br, Raja |
05-25-2019, 17:10 | #8 (permalink) | |
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Before Flashing... Quote:
before flashing phone was working only have problem that some time hangs. For that i have flashed. Now in thick soup. Only DCC firmware can help. If any body have please share it. Thanks Br, Raja | |
05-25-2019, 17:58 | #9 (permalink) |
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Hi sir, Its complete test report. ============ Memory Detection Report =========== Internal RAM: External RAM: Type = DRAM Size = 0xc0000000 (3072MB/24576Mb) NAND Flash: ERROR: NAND Flash was not detected! EMMC: EMMC_PART_BOOT1 Size = 0x0000000000400000(4MB) EMMC_PART_BOOT2 Size = 0x0000000000400000(4MB) EMMC_PART_RPMB Size = 0x0000000000400000(4MB) EMMC_PART_GP1 Size = 0x0000000000000000(0MB) EMMC_PART_GP2 Size = 0x0000000000000000(0MB) EMMC_PART_GP3 Size = 0x0000000000000000(0MB) EMMC_PART_GP4 Size = 0x0000000000000000(0MB) EMMC_PART_USER Size = 0x0000000747c00000(29820MB) UFS: ERROR: UFS was not detected! ============ RAM Test ============ Data Bus Test: [D0] [D1] [D2] [D3] [D4] [D5] [D6] [D7] [D8] [D9] [D10] [D11] [D12] [D13] [D14] [D15] [D16] [D17] [D18] [D19] [D20] [D21] [D22] [D23] [D24] [D25] [D26] [D27] [D28] [D29] [D30] [D31] OK!! Address Bus Test: [A1] [A2] [A3] [A4] [A5] [A6] [A7] [A8] [A9] [A10] [A11] [A12] [A13] [A14] [A15] [A16] [A17] [A18] [A19] [A20] [A21] [A22] [A23] [A24] [A25] [A26] [A27] [A28] [A29] [A30] [A31] OK!! RAM Pattern Test : Writing ... 0x44332211, 0xA5A5A5A5, 0xA5A5A500, 0xA500A500, 0xA5000000, 0x00000000, 0xFFFF0000, 0xFFFFFFFF, OK!! Increment/Decrement Test: Writing... OK!! I think only firmware problem. And Only DCC Firmware need it. Please need help for DCC Firmware. Thanks Br, Raja |
05-25-2019, 21:11 | #10 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | This test meen exactly nothing. It not test for read-only blocks, not test for bad block, also can be lot of other problems in phone what can cause this problem. Was many reports with phones what hang on logo of restart problems e.t.c. what become dead after flashing. In many cases changing emmc flash ic help to solve phone. |
05-26-2019, 08:49 | #11 (permalink) | |
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Emmc ro check Quote:
EMMC is ok..... [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! .... Only need DCC firmware Please. Any body can help. Thanks Br, Raja | |
05-26-2019, 08:54 | #12 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | I'am personally not have any DCC firmware, if somebody will want to help, sure . |
