Avengers Box (Multi Unlocker Box) |
08-22-2018, 15:07 | #1 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Bolivia
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | s9 plus clone mt6580 help Here I leave the information read: Action : Boot Info. Selected 0-By CPU:MT6580 Exe version: Avengers Box MTK 0.5.1 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM7) Boot mode: Preloader Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (28Gb+8192Mb) HYNIX 0x483447316404 EMMC FW VERSION: 87:00:00:00:00:00:00:00 EMMC CID: 90014A483447316404 : 00000000000000 EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe7600000 [3.615 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM14) -Reading GPT Drive OK This phone have FRP partition. Build ID: LMY47I Display ID: LMY47I test-keys Version: 5.1 Build Date: Fri Mar 30 17:48:08 CST 2018 Model: P59 Brand: alps Device: P59 Region: ES Mediatek Version Release: ALPS.L1.MP6.V2.19_HCT6580.WEG.A.L_P55 Partition is damaged or encripted. IMEI[1]: 3588xxxxxxxxx IMEI[2]: 3586xxxxxxxxx Wait untill phone will start charging. All done. [IMG][/IMG] I could only find this software: https://www.tunisiendeveloper.com/20...ne-mt6580.html but I'm wrong Flash files count is :12 Action : Firmware update. Selected Model: 0-By CPU: MT6580 Exe version: Avengers Box MTK 0.5.1 Scenario: [1]Full Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM7) Boot mode: Preloader Using Algo 1. Scatter file loaded, not need emmi. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (28Gb+8192Mb) HYNIX 0x483447316404 EMMC FW VERSION: 87:00:00:00:00:00:00:00 EMMC CID: 90014A483447316404 : 00000000000000 EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe7600000 [3.615 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM14) Flash EMMC Algo Start. Preloader backup already exist, skip saving. Starting flash. FORMAT EMMC FLASH : BEGIN: 0x6a800000 - LEN: 0x10000000 FORMAT EMMC FLASH : BEGIN: 0x7a800000 - LEN: 0x6b780000 [1011]Error: S_NOT_ENOUGH_STORAGE_SPACE Wait untill phone will start charging. All done. [IMG][/IMG] this is the cell phone : [IMG][/IMG] [IMG][/IMG] |
