Avengers Box (Multi Unlocker Box) |
02-15-2020, 15:38 | #1 (permalink) |
Banned Join Date: Dec 2018 Location: Tamilnadu
Member: 2882826 Status: Offline Thanks Meter: 75 | Vivo Y69 Pattern & FRP Failed Log: Code: Exe version: Avengers Box MTK 0.6.6 Selected model: Vivo Y69 Action: Reset Pattern Reinsert phone battery. Battery must be charged. Keep VOL+ button untill inserting USB cable. Detected : MediaTek PreLoader USB VCOM (Android) (COM11) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6755 1 cb00 Using Algo 3. Helio MT6755 phone detected, swithing to helio api Helio enabled DRAM in First Da: TRUE Sending loader..... Helio connect da error, aborting. [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware BBCHIP MT6755 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. Code: Exe version: Avengers Box MTK 0.6.6 Selected model: 0-By CPU MT6750 Action: Reset Pattern Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM11) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6755 1 cb00 Using Algo 3. Helio MT6755 phone detected, swithing to helio api Helio enabled DRAM in First Da: TRUE Sending loader..... Helio connect da error, aborting. [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware BBCHIP MT6755 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. LOG: Code: Action : Reset to factory default. Selected Model: Vivo:Y69 Exe version: Avengers Box MTK 0.6.6 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [11]Detected: MediaTek PreLoader USB VCOM (Android) (COM11) \\?\usb#vid_0e8d&pid_2000#6&67fe735&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [17]META Port Detected: MediaTek USB VCOM (Android) (COM17) USB\VID_0E8D&PID_2007\_ Start sync target, waiting responce..... ChipID: MT6750,S01 [MT6750,S01]Using Algo 3 Resetting phone step 1, wait.... Resetting phone step 2, wait.... ClearValue ok. FormatTCard ok. [0]All done. Log: Code: Exe version: Avengers Box MTK 0.6.6 Selected model: Vivo Y69 [auto]Action: Reset FRP Reinsert phone battery. Battery must be charged. Keep VOL+ button untill inserting USB cable. Detected : MediaTek PreLoader USB VCOM (Android) (COM11) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6755 1 cb00 Using Algo 3. Helio MT6755 phone detected, swithing to helio api Helio enabled DRAM in First Da: TRUE Sending loader..... Helio connect da error, aborting. [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware BBCHIP MT6755 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. |
02-15-2020, 16:53 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Your phone is not Vivo Y69 According to this post, where user boot phone, loader work http://forum.gsmhosting.com/vbb/f820...o-y69-2638382/ Also you removed all info about phone from log. Before posting......."not working" log, check if not exists logs from other users. Just a suggestion. Closed. |
The Following User Says Thank You to orbita For This Useful Post: |
