Avengers Box (Multi Unlocker Box) |
05-12-2019, 12:08 | #1 (permalink) |
Freak Poster Join Date: Dec 2015
Member: 2495033 Status: Offline Thanks Meter: 21 | xt1662 imei repair problem Selected connection metod: Meta Connection Exe version: Avengers Box MTK 0.6.1 Selected phone: XT1662 Action : IMEI REPAIR. IMEI[1] for write : 357556456465468 IMEI[2] for write : 356778453465687 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [28]Detected: MediaTek USB Port (COM28) \\?\usb#vid_0e8d&pid_0003#6&3af1eaa2&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [12]META Port Detected: Android Gadget VCOM Driver (COM12) USB\VID_17EF&PID_74ED&MI_02\7&2BD703A4&0&0002 Start sync target, waiting responce..... [AP]BaseBand CPU : mt6755,S01 Rebooting to meta, wait.... [META]BaseBand CPU : MT6755 [META]SW_VER : XT1662.N.V11 [META]HW_VER : LENOVO6755_66_N_HW Meta mode conected ok, start reading phone.... IMEI to repair: [1] 357556456465468 IMEI to repair: [2] 356778453465687 Clean Boot flag ok. [0]All done. |
05-12-2019, 12:39 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | In mtk phone imei null can be caused by 1.Damaged firmware 2.Damaged hardware 3.Damaged security 4.Erased imei. If phone have erased imei, you can write imei back, if phone have other problem, need to solve first problem what cause null imei(after usually imei come back if was not "..repaired" before) |
05-12-2019, 16:27 | #4 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
In this phones dinamic imei not anymore in userdata it's inside special partition called nvdata. Static imei is hold in nvram partition. And this partitions can be erased only if you will erase it manually. After factory reset even teoreticly is not posible to erase this 2 partitions. | |
05-14-2019, 07:23 | #6 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Instead of check what problem have phone, you started to spam with multiple threads. In second thread what you started, no idea why, you post this log. Code: Selected connection metod: Meta Connection Exe version: Avengers Box MTK 0.6.0 Selected phone: ELBRUS Action : IMEI REPAIR. IMEI[1] for write : 358217071665176 IMEI[2] for write : 358217071717159 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [5]Detected: MTK USB Port (COM5) \\?\usb#vid_0e8d&pid_0003#5&28b2efbf&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [66]META Port Detected: %VCOM% (COM66) USB\VID_17EF&PID_74ED&MI_02\6&2BD703A4&0&0002 Start sync target, waiting responce..... [AP]BaseBand CPU : mt6755,S01 Rebooting to meta, wait.... [META]BaseBand CPU : MT6755 [META]SW_VER : KUNGFU.ROW.N.V13 [META]HW_VER : LENOVO6755_66_N_HW Meta mode conected ok, start reading phone.... IMEI to repair: [1] 358217071665176 Phone imei[1] : 358217071665176 IMEI to repair: [2] 358217071717159 Phone imei[2] : 358217071717159 Clean Boot flag ok. [0]All done. Will tell you again, for phone really not matter what you think. If problem exists, you must solve this problem, and really not matter what you think. You can do what you want, really can't help you more. You can continue with "i'am think in phone is all ok" or you can solve problem and have repaired phone. Finally is your choise. Last edited by orbita; 05-14-2019 at 07:29. |
05-14-2019, 07:39 | #7 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Also...from what i'am see, you not performed first basic check what need to do in this case. Try to read simlock info in meta mode and see what display exe. Damaged security is also a cause of null imei. |
The Following User Says Thank You to orbita For This Useful Post: |
05-14-2019, 10:54 | #9 (permalink) | |
Member: 2495033 Status: Offline Thanks Meter: 21 | and this thread is not belong to me Quote:
05-14-2019, 12:42 | #11 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Your solution can be damaged secuity(i'am already sayed how to check this) Can be firmware, or can be hardware. What meen sec_nvram.bin i'am not know and i'am not have this file. We make very long thread for easy to solve problem, not need to think here if is ok or not, simple need to check this parts. |
