08-21-2014, 10:23 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | A21 shows sd card blank or has unsupported filesystem it happen after deleating some picturs and unwanted files (For Him) from fone and sd card to save space , all done with connected with usb cable. after erasing ,restarted fone shows this error.... only WITH SD CARD INSERTED IT SHOWS THIS ERROR: Code: BLANK SD CARD SD CARD BLANK OR HAS UNSUPPORTED FILESYSTEM still shows same error ... Dont say..Replace sd card. Need help. Thank You |
08-21-2014, 11:10 | #2 (permalink) |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | not clear about... is this massage with internal sd card or you face problem with external sd card ,,,,,. if you faced with external sd card then just format sd card from setting storage or format both sd card |
The Following User Says Thank You to gsm mithun roy For This Useful Post: |
08-21-2014, 11:12 | #3 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | im face this problem but model different my track is device wipe erased card with in this device not a system download file maneger some differents types one by 1 check for sd card locatoin ....... |
The Following User Says Thank You to .....::::GsmAdeel:::::..... For This Useful Post: |
08-21-2014, 11:20 | #4 (permalink) | ||
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Quote:
not shows in storage as external drive Quote:
any other sugessions...? | ||
08-21-2014, 12:28 | #5 (permalink) |
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | if not show in storage at the top of screen where all notificition shown there must it shown it click to BLANK SD CARD SD CARD BLANK OR HAS UNSUPPORTED FILESYSTEM error massage then format if it support or thing you can try format a sd card with fat32 /fat/ntfs file system with pc |
06-06-2018, 10:27 | #10 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2065164 Status: Offline Thanks Meter: 1 | May be your SD card is corrupt or damaged. Follow below steps to fix the issue: Connect SD card to Windows computer. Click Start and type CMD in the search bar and press ENTER. Type the following command: attrib -h -r -s /s /d f:\*.* in the new opened command prompt window and press ENTER. Note: Replace f: with your SD card drive letter name. Information source: rescuedigitalmedia(dot)com |
