Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Karbonn
Old 04-14-2013, 17:37   #1 (permalink)
..::Nokian Care®::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,266
[Guide] All Karbonn Mobiles Hard Reset Procedures
All Karbonn Mobiles Hard Reset Procedure & Guide Should Be Posted Here Only.
Br,
azam
Old 04-14-2013, 17:50   #2 (permalink)
Member: 505794
Thanks Meter: 2,266
Karbonn A15 Hard Reset Done
Press & Hold Volume UP + Power at same time after 5 seconds recover comes.
Br,
azam
Old 04-21-2013, 16:01   #3 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,052
Karbonn A21 hard reset
Press Power key + Volume up key + Home Key
and then select clear data.
Alex
Old 04-21-2013, 16:03   #4 (permalink)
moulnisky's Avatar
Member: 947561
KARBONN A9 Hardreset
-switch off
-press vol up and power on key together (it takes pretty long time)
-You will enter green screen, but need to press the power key again
-Now you will enter the red screen.
-There on your android will appear and all the options too.
-For selecting use the volume up and down keys, but to select an entry you need to press the power on key for a little longer.
Power on and vol down key will probably lead you to download mode.
do factory reset & its done
Alex
Old 04-22-2013, 07:11   #5 (permalink)
Member: 505794
Thanks Meter: 2,266
Karbonn A1 Hard Reset
[IMG]http://3.bp.********.com/-iEFxEcEjua8/UNXidwKDb_I/AAAAAAAADVg/8hcQztKPD44/s1600/dfdfrrr.jpg[/IMG]
  • Power off mobile
  • Now press Home+center+power Key altogether
  • After 10-15 sec Triangle symbol will be appear
  • then Press call button for recovery menu
  • Use volume buttons to scroll option
  • Now press center button to select option
Enojy................
Br,
azam
Old 04-22-2013, 16:55   #6 (permalink)
mak1983's Avatar
Member: 1704666
Sonork: 100.1652565
Thanks Meter: 157
need all karbonn hard rest solution
Old 04-25-2013, 10:06   #7 (permalink)
Member: 669677
Sonork: 100.1608909
Thanks Meter: 27
how to hard reset karbonn A5
Thanks
Old 05-03-2013, 10:13   #8 (permalink)
Member: 588045
Thanks Meter: 19
how to hard reset karbonn s5
Old 05-07-2013, 08:55   #9 (permalink)
Member: 505794
Thanks Meter: 2,266
Karbonn Mobile A3 Google Account Remove Done
Karbonn Mobile A3 Google Account Remove Done With Android Multi Tool
Put your phone into fast boot mode using Volume Down & Power Key.
Now Open Android Multi Tool press 8 from keyboard finaly press Enter
Wait for reboot & enjoy.
Br,
azam
The Following User Says Thank You to ..::Nokian Care®::.. For This Useful Post:
Old 05-13-2013, 08:39   #10 (permalink)
mortal90210's Avatar
Member: 199340
Sonork: 100.1592925
Thanks Meter: 192
Karbonn TA-Fone A37 HARD RESET
Karbonn TA-Fone A37
Procedure.
press volume down with power key for 10 sec.
recovery/test screen appear,show 5 options
click on 4th option (eMMC)via volume key
then press power key.
finished.
press thanks only if u like.
The Following 4 Users Say Thank You to mortal90210 For This Useful Post:
Old 05-25-2013, 05:23   #11 (permalink)
Member: 1503859
Sonork: 100.1672251
Thanks Meter: 43
how to karbonn a-27 hard reset ???????????????????????? please urgent help me.
Old 06-08-2013, 15:02   #12 (permalink)
Member: 199340
Sonork: 100.1592925
Thanks Meter: 192
Karbonn a30 hard reset guide
Hi all
karbonn a30 reset procedure is
hold power+up key
recovery menu appear
click home key then ,option select via apps key.
Done
enjoy.
The Following User Says Thank You to mortal90210 For This Useful Post:
Old 06-09-2013, 12:02   #13 (permalink)
Member: 337100
Sonork: 100.1606722
Thanks Meter: 75
how to hard reset karbonna A2+ ................
Old 06-12-2013, 07:38   #14 (permalink)
KARNVIR's Avatar
Member: 741065
Thanks Meter: 139
Karbonn S5 Titanium Hard Reset
Hard Reset:
Press and hold VOLUME UP + POWER KEY
now you see green screen don't release volume up key
after 10 seconds you see red screen, now release Volume up key.
now you see recovery options.
select wipe data with factory reset and press power key for 2 sec.
now select yes -- delete all user data and press power key for 2 second.
now reboot device.
Old 06-21-2013, 11:37   #15 (permalink)
Sanjeev_Chauhan's Avatar
Member: 1663011
Sonork: 100.1609944 QQ.1504180136
Thanks Meter: 1,594
Karbon A21 Google Account & Pattern Unlock Done
Karbon A21 Google Account & Pattern <<<<Unlock Done>>>>
u need to boot ur phone into fastboot (Follow exactly what i said bellow)
Power off phone
Pull out Battery & insert it again
Press Volume Up + Power Button for 5 seconds
Ur phone will boot up with fastboot
Now open Android Multi Tool & Press 8 from ur PC keyboard & press Enter
Enjoy.....
Br-Sanjeev Chauhan
India
Android Multi Tools v1.02b Download Here
The Following 2 Users Say Thank You to Sanjeev_Chauhan For This Useful Post:
Page generated in 0.27299 seconds with 9 queries
